there has been a questions whether there is an Australian topic where we can discuss general questions and to start closer cooperation between the Australian TTN communities and its users.
I hope this new topic can achieve this goal.
As the first post we had a talk to couple of people to decide on the preferred channels to use in Australia to facilitate roaming between different cities/communities.
For this it is essential to use the same channels.
So far ch 8-15 was the winner in spite we use different ones here in Melbourne.
However, we are ready to change in order to help in this compatibility issue.
If you are a GW operator or an initiator, we would like to know your opinion on this or on anything else that is specific to the Australian communities.
Thanks.
I am not sure whether this is the right thread but I have to start somewhere. I am currently trying to connect to the TTN gateway on the roof of the QUT building, Brisbane, Australia.
The hardware I am using is Arduino-Pro/Pro Mini-based, i.e. ATmega328, 3.3V, 8MHz + Dragino LoRa Bee, 915 MHz, based on HopeRF RFM95W (SX1276).
The Arduino library I am using is the IBM LMIC library to be downloaded with the Arduino library manager:
I am porting it to the Australian regulations as far as I need it to connect the TTN gateway. The frequencies are already adapted. (there is more: TX power, duty cycle, SF, …). I would like to send data via 125 kHz bandwith channels with SF10 and 30 dB power. (I don’t know if my hardware can provide this power). According to the companion “LoRaWAN™ Regional Parameters, v1.0” it is required to use 20(!) channels for frequency hopping when sending with max output power 30 dB.
When I understand your TTN gateway config file correctly you provide 8 RX channels on the gateway:
Just for clarification, am I right when I assume you are using the following channels on the QUT Brisbane TTN gateway:
AU ISM 915 Ch# | direc | f/MHz | BW/kHz | data rate 8 | up | 916.8 | 125 | DR0 - DR3 9 | up | 917.0 | 125 | DR0 - DR3 10 | up | 917.2 | 125 | DR0 - DR3 11 | up | 917.4 | 125 | DR0 - DR3 12 | up | 917.6 | 125 | DR0 - DR3 13 | up | 917.8 | 125 | DR0 - DR3 14 | up | 918.0 | 125 | DR0 - DR3 15 | up | 918.2 | 125 | DR0 - DR3 65 | up | 917.5 | 500 | DR4 0 | down | 923.3 | 500 | DR8 - DR13 1 | down | 923.9 | 500 | DR8 - DR13 2 | down | 924.5 | 500 | DR8 - DR13 3 | down | 925.1 | 500 | DR8 - DR13 4 | down | 925.7 | 500 | DR8 - DR13 5 | down | 926.3 | 500 | DR8 - DR13 6 | down | 926.9 | 500 | DR8 - DR13 7 | down | 927.5 | 500 | DR8 - DR13
Hi guys,
I need a pointer or ten to push me in the right direction.
I got a spare Raspberry and decided I want to learn a bit more about LoRa so I ordered one of those Modtronix inAir9B devices. Configured it according to the CongDucPham’s documentation. Once it booted up I realised the frequency is wrong and I don’t understand enough of the code to know what to change.
Is there a version of the code that is for Aus? or is there other code/lib that I can use?
Hey Rolf, I’m trying to do the same with LMIC and an Adafruit Feather 32u4 rfm95w Lora 900mhz and am getting stuck on what frequencies I should be defining for Australia. Did you manage to resolve, would you mind sharing where you got to? Cheers Dave
Not sure if it is a limitation on my device which is a Dragino Rpi Hat v1.4
The problem I have is it seems to transmit for 5~10 minutes until my gateway doesn’t seem to see it anymore - even though the device is telling me it is transmitting.
I didn’t clarify in original post, that this is after updating the frequencies and compiling to use the
// Default frequency plan for AU 915MHz
enum { US915_125kHz_UPFBASE = 915200000,
US915_125kHz_UPFSTEP = 200000,
US915_500kHz_UPFBASE = 915900000,
US915_500kHz_UPFSTEP = 1600000,
US915_500kHz_DNFBASE = 923300000,
US915_500kHz_DNFSTEP = 600000
enum { US915_FREQ_MIN = 915000000,
US915_FREQ_MAX = 928000000 };
Is there a way I can output with the tx sent what frequency it is chirping on without using a spectrum analyser?
I’m currently using lmic/example/thethingsnetwork-send examples
Hey everyone, I’m new to the forum and trying to get my TTGO T-BEAM working as a TTN node in Sydney. I’ve just been using us915 with the LMIC Library, which could the be problem, so I’ve recently switch to au915 in the config file. Any insight into the issue would be great, details of my post is here TTGO T-Beam
I just join this community today. I am from Melbourne Australia .
Could you please anyone help me about the payload formatter? How can I make the application in TTN where I will find the sensor data in human readable format . Like temperature , humidity or motion .
Looking forward to hearing from you .
That will depend on the sensor device (end node) and payload format you are using - can you post more details - home-brew or proprietary payload used? Device manufacturer defined payload (e.g. Laird T&H Connectivity, iMST/SMTC LoRaMOTE, etc.), Standard payload e.g. Cayenne LPP?, JSON?, how do you want to pull data from the system? (Webhooks, MQTT, etc) where do you want to view - console, 3rd party Integration/Display options (e.g. Datacake, Cayenne, Grafana, etc.)
Have you read through the available documentation on TTN & TTI or viewed some of the Labs/Use cases - these will give you a good start and grounding for framing your requirements and asking the right questions.
