Hi everyone,
we would like to roll out TTN at Prague / Czech republic. 10 pcs of Loranks are on the stock and another 10 pcs are on the way. I am waiting for reply from Wienke to officially join TTN. Feel free to ask me.
Z.
Hi everyone,
Z.
Hi, why are you waitting? At the morning I activated RPi and simply start sending status packets
http://ttnstatus.org/gateways/B827EBFFFF39F6E7
I have lit new GW in suburb Prague. I can not see it on the map. The gateway is registred as b827ebfffeae70f3
Any idea?
OK, now I see it…
Hi all,
I just tried to test Prague TTN coverage. I choosed measure point on Petrin Tower 389 m AMSL - about 300m high hill. I supposed most of active gateways will receive RisngHF Temperature/Humidity sensor with small PCB antenna. For measure I used TTNMapper server with my mobile. Here I attached snapshot of screen. I suppose I reached all Prague active gateways. Missed one active just day before - Zabehlice/Zirovnicka was probably switched off. Quite surprising is not reached Kladno GW. May be low height of it? Farest Gateway i Luziny (abt 7km) (out of picture in southwest) Is my testing GW - iFemtocell with whip antenna on window,
Hi everyone, I know this is quite an old thread but I’ll still give it a go. Is there any 433mHz gateways in Prague? And if so do you know where? Im not sure where to look as I’m new to LoraWAN. Thank you for the help.
433MHz is very very niche, ie rare, for LoRaWAN - if you’ve got a 433 radio module you will be far better off getting a 868 one. If you have a 433 gateway, send it back to the supplier and get an 868!
Hi, thanks for the reply! We’re actually making our own modules with a esp32 and sx1278 radio. We’re in the process of moving to 868 but currently we have some nodes running on 433 that we’d like to get some value from, hence the question.
