My TTIG no longer powers up by plugging in into AC 120v power (US) with the supplied adapter. I am only able to power it through USB-C now. Any suggestions or recourse for replacement?
I made no changes or modifications to the TTIG. I removed the adapter to check the pins and they don’t appear to be burned or corroded.
IIRC they use a standard (Meanwell?) PSU module that a competent/qualified electrician/electronics engineer could swap out…if outside warranty. If still under warranty simply get it swapped?! Personally I run all mine off external USB C PWR as this removes a source of heat from inside the box…potentially extending its life. Removes a switching PSU from close proximity to the more sensitive electronics…potentially improving sensitivity, improving noise floor & reliability. And allows better positioning vs being tied to a mains power outlet, improving installation flexibility. So what’s to loose Search Forum for prior pictures of internals and comments on opening box if going down replacement PSU route…
