We have a new beta firmware for The Things Indoor Gateway containing some nice new features. Of these, (at the least) the following are useful for us
The gateways respond to WS Pings. This really helps connectivity.
We’d like some volunteers to test the new firmware. If you are interested, please send me your EUI via private message and I’ll trigger a firmware update.
Note: If there’s a problem, we can easily rollback.
I rebooted my TTIG and it seemed to load OK - that is, it took a bit longer than normal to boot with various flashing yellow/green light patterns, but eventually came up with the LED solid green. However, it does not show up as connected through the TTN Console. Tried rebooting again with no change - solid green, no connection.
Does the beta firmware interfere with the console status display or do I need to go through the configuration steps again? Is there something I can do on my side to help troubleshoot?
Can you somewhere see if your TTIG has got his update?
On the Kickstarter gateway you can check /info.
The TTIG give no info if you go with http(s), or is this hidden?
Regards
Johan
It will be very useful (and common practice) to be able to see locally (‘on the device’) what version of the firmware is installed, e.g. on the configuation page (without requiring connection to any backend services).
If this is currently not supported, it should be added to the new firmware.
I think He (bluejedi) mentioned and also I think why is there no status page at the TTIG to check it locally. I could be build in in a new firmware off the TTIG.
then you need physical access to your device
And that is not always possible, I have install TTIG’s at familie houses ect.
But I see the work what you want to from server side to get the info top job.
Go to Messages (select your user icon top-right, then double-click the message icon), select ‘New message’ and add the username to whom you want to send a PM.
Thanks. Well I was looking at those places and was not able to find either a ‘Message’ at the user nor a ‘New Message’ button. Why should this not be possible?
BR
It seems the firmware is already reported in platform on the NOC? (Or are these new details for the TTIG? I’ve used the same details to get a list of The Things Gateway firmware versions almost two years ago.)
ttnctl gateways status eui-58a0cbfffe80050e
INFO Discovering Router...
INFO Connecting with Router...
INFO Connected to Router
INFO Received status GatewayID=eui-58a0cbfffe80050e
Last seen: 2020-06-19 10:17:42.961471121 +0200 CEST
Timestamp: 0
Reported time: 2020-06-19 08:37:51.83752521 +0200 CEST
Platform: minihub - Firmware 2.0.4 - Protocol 2
Frequency Plan: EU_863_870
Bridge: gs.v3.
Rtt: not available
Rx: (in: 0; ok: 0)
Tx: (in: 0; ok: 0)
