TTIG Unable to connect
I registered my TTIG EUI 58-A0-CB-FF-FE-80-2C-ED and it’s working on my wifi no problem. The green LED is doing the fast blink and never going solid. I’m not sure what to do from here.
Serial output from the device:
dhcp client start...
1970-01-01 00:00:06.230 [SYS:DEBU]   Free Heap: 54768 (min=53256) wifi=1 mh=3 cups=0 tc=0
1970-01-01 00:00:07.236 [SYS:DEBU]   Free Heap: 54768 (min=53256) wifi=1 mh=3 cups=0 tc=0
ip:10.0.5.122,mask:255.255.255.0,gw:10.0.5.1
1970-01-01 00:00:08.240 [SYS:DEBU]   Free Heap: 54768 (min=53256) wifi=5 mh=3 cups=0 tc=0
1970-01-01 00:00:08.248 [CUP:INFO] Stopping TC and starting CUPS
1970-01-01 00:00:08.250 [CUP:INFO] Starting a CUPS session
1970-01-01 00:00:08.259 [CUP:INFO] Connecting to CUPS ... https://mh.sm.tc:7007 (try #1)
1970-01-01 00:00:08.269 [any:INFO] cert. version     : 1
serial number     : 01
issuer name       : CN=Root CA, OU=TrackCentral (ez5Cj0eN), O=TrackNet.io, C=CH
subject name      : CN=Root CA, OU=TrackCentral (ez5Cj0eN), O=TrackNet.io, C=CH
issued  on        : 2018-11-22 10:23:38
expires on        : 2024-11-20 10:23:38
signed using      : ECDSA with SHA256
EC key size       : 256 bits
1970-01-01 00:00:08.294 [AIO:INFO] cups has no cert configured - running server auth and client auth with token
1970-01-01 00:00:08.447 [CUP:VERB] Retrieving update-info from CUPS https://mh.sm.tc:7007...
1970-01-01 00:00:15.074 [SYS:DEBU]   Free Heap: 26088 (min=25584) wifi=5 mh=7 cups=1 tc=0
1970-01-01 00:00:15.595 [any:VERB] Failed to retrieve TCURI from CUPS: (404) Not Found
1970-01-01 00:00:15.598 [AIO:DEBU] [2] HTTP connection shutdown...
1970-01-01 00:00:15.605 [SYS:INFO] sys_inState - Ignoring state transition: 5
1970-01-01 00:00:15.608 [CUP:INFO] Interaction with CUPS failed - retrying in 1m
1970-01-01 00:00:15.612 [TCE:INFO] Starting TC engine
1970-01-01 00:00:15.618 [TCE:ERRO] No TC URI configured
1970-01-01 00:00:15.627 [TCE:INFO] INFOS reconnect backoff 0s (retry 0)
1970-01-01 00:00:15.631 [TCE:ERRO] No TC URI configured
1970-01-01 00:00:15.633 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
Before I return this unit, are there any possible next steps to debug what is going on?
