Is The Things Industries Indoor Gateway (TTIG) is a stable device?
There have been ample reports here which seem to indicate that the combination of the gateway software and the protocol translation servers it connects to is unreliable at present. And being closed source, there’s essentially nothing you can do to improve the situation.
which gateway would you recommend for TTN?
Something where you can rebuild the system software from source, and (if it’s going where it’s at all hard to get at) where the base computer is not a Raspberry Pi and does not depend on an SD card (though if it’s going to be where you can pop in a new card if it eats itself, a pi can be an easy path to initial success). Most of the more “commercial” platforms like Multitech, TTOG, etc have their own chosen compact flash-based Linux. Overseas vendors seem to be doing good things with the Atheros and Mediatek OpenWRT router platforms - for example I have a RAK 2758 box running a built from source stack and several prototypes of a fully custom design using the same Mediatek SoC and concentrator card integrated in a way that hopefully better fits specific needs of where they will be installed, also have several of what are essentially pi gateways using an emmc-based OrangePi instead which now have nearly a year of shakedown on them to understand the rare issues. If you want to use post-UDP connectivity protocols some work combining packet forwarders supporting those with sources vendors have modified to work around SoC SPI oddities may be needed, but it all ultimately traces back to the same origins in Semtech’s version so that should be quite doable as a merge. Getting a bit far from the topic of this thread however…
I’m still wondering if it’s possible to get the TTIG timesynced via NTP.
It is sending a time in metadata meanwhile, but does not sync via NTP.
Any ideas how to solve this?
In Basic Station firmware updates are handled by the Configuration and Update Server via the CUPS protocol. How exactly this will be managed and how updates will be initiated I don’t know.
My personal guess is that we may have to wait for availability of TTN V3 before TTIG firmware can be remotely updated (but I may be wrong).
Curious: why is that gateway wall time so important to some of you? I don’t think one can expect a great accuracy anyway? (Even if it would use NTP every hour or so, I doubt it’s useful for, e.g. triangulation?)
Did you truly use the USB connector (rather than soldering something to the UART connector)? If yes: how?
According TTIG : The Things Indoor Gateway I’ve placed a 470 Ohm SMD Resistor on the spare R86 position … this enables the (initially disabled) CP2102 and you get Debug Output on the USB Interface, it’s an alternative to using a RS232 / USB Bridge.
@bei: " A wild guess at the root cause" … there was an error in the parameters of my Arduino node. It violated the “fair use policy”, sending a packet every 14 secs. I’ve corrected this mistake … and voila … connection resets gracefully in case of power or wlan loss. It’s ok for now, but theres potential for Denial of service attack to TTIGs.
Sorry, forget my last post … after forwarding my Arduino Temp Sensor without problems for the whole weekend my TTIG hangs again …
… seems not the same issue as mentioned above, after 23 Minutes it begins forwarding packets again. The hang seems not persistent as it was in the past.
I’m sorry, but for my environment the TTIG isn’t a reliable solution, what’s about the LG308 ? Maybe the better solution ?
Missing data is one thing, but _wrong_data should be fixed. I don’t like a product which sends wrong data to my backend. I can’t fix it by myself, I have to wait till TTN fixes the product they sold. Up to now I found no resources explaining what will be fixed when. That’s some kind of after sales support I expect when I buy a product.
Last time I checked TTN didn’t sell any gateways. RS Components and several dealers do sell gateways. Your supplier should be the first port of call when something does not work as described.
However TTNs name is associated with the product, so some improvements or comments would be useful. @wienkegiezeman?
OK, that’s not so easy for a beginner. The TTIG is not provided by The Things Network (TTN). Got it. It is advertised by “The Things Industries” and offered on “The Things Industries” homepage as product, (distributed via RS-Components). Now I’m wondering, if this is not the right form for the TTIG, where can I file an issue for The Things Industries …
After running my TTIG now for some time without greater problems, I think @bei’s wild guess in his post on Sept 3rd is right. Since I’ve corrected the sending interval in my Arduino Node my TTIG forwards all my sensors flawlessly. A break in my WiFi Connection or a Power Fail isn’t a problem anymore.
Bad news: Each of my two TTIGs doesn’t connect since 2 days.
They blink fast green and sometimes green/red.
Disconnecting power for more then 10 minutes doesn’t help.
Debug Output says:
[AIO:INFO] cups has no cert configured - running server auth and client auth with token
[AIO:ERRO] [-1] HTTP connect failed: UNKNOWN ERROR CODE (0052)
[AIO:DEBU] [-1] HTTP connection shutdown…
[CUP:ERRO] CUPS connect failed - URI: https://mh.sm.tc:7007
and here the corresponding Debug lines of an earlier successful boot:
[CUP:VERB] Retrieving update-info from CUPS https://rjs.sm.tc:9191…
[AIO:DEBU] [2] HTTP connection shutdown…
[CUP:INFO] Interaction with CUPS done (no updates) - next regular check in 1d
[TCE:INFO] Starting TC engine
Both URIs (https://mh.sm.tc:7007 and https://rjs.sm.tc:9191) are connecting with my Firefox Browser
and show the following message:
{“error”:“Invalid or missing input Expecting value: line 1 column 1 (char 0)”}
Both TTIGs are on
[SYS:DEBU] Station Version 2.0.0(minihub/debug)
[SYS:DEBU] Version Commit e17c5af
[SYS:DEBU] Station Build 2018-12-06 09:30:37
[SYS:DEBU] Firmware Version 2.0.0
[SYS:DEBU] FW Flavor ID semtech0
[SYS:DEBU] Model minihub
This TTIG was reset by pressing the Reset Button in Config Mode.
The other TTIG was left in its state.
The behaviour of both seems to be the same.
Hi @ll, the main problem of not connecting was a misconfigured DNS Server on my site. But the general Problem, if TTIG is disconnected by WLAN or Power interruption stays the same as before, has even got worse since the timeout was rised from 60 to 600 seconds. I have to disconnect the TTIG for 10 minutes, then the connection is ok for sometimes half a day, sometimes even half an hour. The thing is absolutely unreliable. I’ve transported my second TTIG to another location, where it connects via a Sophos firewall to fibre cable (an absolutely reliable company network), but problems are the same … my next try will be a connection via mobile phone tethering, this worked some months ago. It’s an epic fail, since some months i try to get this damned thing working.
As it is running on an ESP processor, I know a thing or two about those.
You may want to check the following for a very stable WiFi:
Use fixed channel for the wifi used by this gateway.
Test with B/G only set in the access point (or use a B/G-only one) to see if the gateway will accept it.
Try to use an AP for only ESP base units.
My indoor gateway is also as unstable as a drunk on roller skates for the last few days.
For example we had to power cycle everything here in house and thus the gateway connected before the cable modem had a connection. This was apparently enough to not being able to make a connection to the TTN backend. It is now powered off to see later this evening if it can connect again.
It would be nice to know what is wrong here and if there is something we as users can do to make it reliable again.
