Does TTN Mapper show gateways when it only received "experimental" data?
The http://ttnmapper.org/faq/ states:
My results are not showing up on the map
Did you mark your data as experimental? If so, the data will not show on the main map, but on a separate map containing only your experiment. Please disable experimental mode in the app so that you can contribute to the global map of TTN coverage.
Does that mean I have to delete the “Experiment name” in the integration, also? In other words, if a gateway only has received Data with a set “Experiment name” so far - will this force ttnmapper to not show this Gateway?
yes. After deletion of the “Experimental name” in the integration and after about 18h the Gateway appears on ttn mapper. Would be nice if this could be technically clarified and added to the FAQ also
