Hardware TTGO LORA OLED VS 2.1
CODE https://github.com/rwanrooy/TTGO-PAXCOUNTER-LoRa32-V2.1-TTN
After successfully connecting and posting data via ABP I have been unable to switch this codebase over to use OTAA even though the process is to simply change a #define
Its puzzling because I can switch back and get ABP working perfectly but OTAA simply times out at “Joining TTN”. I have switched verbose debugging on in the LMIC library and get the message below.
The gateway is a few kilometres away so I tried a Things Node to make sure it was in range and the Things Node works flawlessly, even though it has only a tiny internal aerial.
Any ideas?
Joining TTN…
343150: engineUpdate, opmode=0xc
833881: engineUpdate, opmode=0xc
833973: TXMODE, freq=868100000, len=23, SF=7, BW=125, CR=4/5, IH=0
1148601: setupRx1 txrxFlags 00 --> 01
start single rx: now-rxtime: 3
1149224: RXMODE_SINGLE, freq=868100000, SF=7, BW=125, CR=4/5, IH=0
rxtimeout: entry: 1152519 rxtime: 1149217 entry-rxtime: 3302 now-entry: 5 rxtime-txend: 311126
1210991: setupRx2 txrxFlags 0x1 --> 02
1211474: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 1228145 rxtime: 1211467 entry-rxtime: 16678 now-entry: 5 rxtime-txend: 373376
1228446: processRx2Jacc txrxFlags 0x2 --> 00
1228741: engineUpdate, opmode=0xc
5215401: engineUpdate, opmode=0xc
5215486: TXMODE, freq=868300000, len=23, SF=7, BW=125, CR=4/5, IH=0
5530371: setupRx1 txrxFlags 00 --> 01
5530733: RXMODE_SINGLE, freq=868300000, SF=7, BW=125, CR=4/5, IH=0
rxtimeout: entry: 5534027 rxtime: 5530726 entry-rxtime: 3301 now-entry: 4 rxtime-txend: 311126
5592496: setupRx2 txrxFlags 0x1 --> 02
start single rx: now-rxtime: 4
5592983: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 5609655 rxtime: 5592976 entry-rxtime: 16679 now-entry: 4 rxtime-txend: 373376
5609956: processRx2Jacc txrxFlags 0x2 --> 00
5610249: engineUpdate, opmode=0xc
9598820: engineUpdate, opmode=0xc
9598905: TXMODE, freq=868500000, len=23, SF=7, BW=125, CR=4/5, IH=0
9913523: setupRx1 txrxFlags 00 --> 01
9914153: RXMODE_SINGLE, freq=868500000, SF=7, BW=125, CR=4/5, IH=0
rxtimeout: entry: 9917447 rxtime: 9914146 entry-rxtime: 3301 now-entry: 5 rxtime-txend: 311126
9975915: setupRx2 txrxFlags 0x1 --> 02
9976403: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 9993075 rxtime: 9976396 entry-rxtime: 16679 now-entry: 5 rxtime-txend: 373376
9993377: processRx2Jacc txrxFlags 0x2 --> 00
9993670: engineUpdate, opmode=0xc
13660568: engineUpdate, opmode=0xc
13660653: TXMODE, freq=868100000, len=23, SF=8, BW=125, CR=4/5, IH=0
13978278: setupRx1 txrxFlags 00 --> 01
13978905: RXMODE_SINGLE, freq=868100000, SF=8, BW=125, CR=4/5, IH=0
rxtimeout: entry: 13982472 rxtime: 13978898 entry-rxtime: 3574 now-entry: 5 rxtime-txend: 311126
14040668: setupRx2 txrxFlags 0x1 --> 02
14041155: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 14057827 rxtime: 14041148 entry-rxtime: 16679 now-entry: 4 rxtime-txend: 373376
14058129: processRx2Jacc txrxFlags 0x2 --> 00
14058421: engineUpdate, opmode=0xc
