Hi there, I bought a Dragino trackerD to hopefully have a better start with TTN and do some range mapping etc. While its open hardware, this device comes ready-to-use, but I don’t get it to sucessfully join the network.
I followed the instructions and quickstart guide but get no events on the TTN console.
I know that here is coverage and I also used different locations that have even better coverage … The LoraWan Ver. 1.0.3 is selected, as well as SF12 frequency plan
The tracker gets stuck in a join loop:
[19:54:45:961] rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)␍␊
[19:54:45:961] configsip: 188777542, SPIWP:0xee␍␊
[19:54:45:961] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00␍␊
[19:54:46:061] mode:DIO, clock div:1␍␊
[19:54:46:061] load:0x3fff0030,len:1284␍␊
[19:54:46:061] load:0x40078000,len:12836␍␊
[19:54:46:061] load:0x40080400,len:3032␍␊
[19:54:46:061] entry 0x400805e4␍␊
[19:54:46:463] Wakeup was not caused by deep sleep: 0␍␊
[19:54:46:463] TrackerD ,v1.4.7␍␊
[19:54:46:463] EU868␍␊
[19:54:47:984] TDC:1200000␍␊
[19:54:47:984] BAT:4002 mV␍␊
[19:54:47:984] Packet queued␍␊
[19:54:47:984] 97256: EV_JOINING␍␊
[19:54:52:848] 401404: EV_TXSTART␍␊
[19:54:53:054] 413932: TXMODE, freq=868500000, len=23, SF=7, BW=125, CR=4/5, IH=0␍␊
[19:54:58:118] start single rx: now-rxtime: 4␍␊
[19:54:58:118] 730183: RXMODE_SINGLE, freq=868500000, SF=7, BW=125, CR=4/5, IH=0␍␊
[19:54:58:118] rxtimeout: entry: 730708 rxtime: 730172 entry-rxtime: 536 now-entry: 6 rxtime-txend: 312375␍␊
[19:54:59:116] start single rx: now-rxtime: 4␍␊
[19:54:59:116] 792682: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0␍␊
[19:54:59:348] rxtimeout: entry: 807033 rxtime: 792672 entry-rxtime: 14361 now-entry: 5 rxtime-txend: 374875␍␊
[19:54:59:348] 807055: EV_JOIN_TXCOMPLETE: no JoinAccept␍␊
[19:56:04:005] 4848724: EV_TXSTART␍␊
[19:56:04:212] 4861303: TXMODE, freq=868100000, len=23, SF=7, BW=125, CR=4/5, IH=0␍␊
[19:56:09:276] start single rx: now-rxtime: 4␍␊
[19:56:09:276] 5177554: RXMODE_SINGLE, freq=868100000, SF=7, BW=125, CR=4/5, IH=0␍␊
[19:56:09:276] rxtimeout: entry: 5178078 rxtime: 5177543 entry-rxtime: 535 now-entry: 6 rxtime-txend: 312375␍␊
[19:56:10:274] start single rx: now-rxtime: 4␍␊
[19:56:10:274] 5240053: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0␍␊
[19:56:10:506] rxtimeout: entry: 5254403 rxtime: 5240043 entry-rxtime: 14360 now-entry: 5 rxtime-txend: 374875␍␊
[19:56:10:506] 5254425: EV_JOIN_TXCOMPLETE: no JoinAccept␍␊
[19:57:14:361] 9245964: EV_TXSTART␍␊
[19:57:14:567] 9258491: TXMODE, freq=868300000, len=23, SF=7, BW=125, CR=4/5, IH=0␍␊
[19:57:19:631] start single rx: now-rxtime: 3␍␊
[19:57:19:631] 9574741: RXMODE_SINGLE, freq=868300000, SF=7, BW=125, CR=4/5, IH=0␍␊
[19:57:19:631] rxtimeout: entry: 9575266 rxtime: 9574731 entry-rxtime: 535 now-entry: 6 rxtime-txend: 312375␍␊
[19:57:20:629] start single rx: now-rxtime: 3␍␊
[19:57:20:629] 9637241: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0␍␊
[19:57:20:861] rxtimeout: entry: 9651590 rxtime: 9637231 entry-rxtime: 14359 now-entry: 5 rxtime-txend: 374875␍␊
[19:57:20:861] 9651612: EV_JOIN_TXCOMPLETE: no JoinAccept␍␊
I already doublechecked DevEUI / JoinEUI / App Key (copied from logger terminal itself) and re-created the node setup manually and as wizzard.
I read different posts on the tracker, but have no idea what causes the issue. Some mention that downlink timing is ciritcal, but is it wise to tweak it manually?
