TrackerD - no JoinAccept
Having difficulty connecting a TrackerD to TTN. Had success with a LSN50 v2. Using the LPS8N gateway.
Here’s what’s showing up in HTerm:
57682195: EV_JOIN_TXCOMPLETE: no JoinAccept<\r><\n>
58450102: EV_TXSTART<\r><\n>
58462678: TXMODE, freq=903100000, len=23, SF=10, BW=125, CR=4/5, IH=0<\r><\n>
start single rx: now-rxtime: 4<\r><\n>
58798239: RXMODE_SINGLE, freq=925700000, SF=10, BW=500, CR=4/5, IH=0<\r><\n>
rxtimeout: entry: 58799139 rxtime: 58798231 entry-rxtime: 908 now-entry: 5 rxtime-txend: 312375<\r><\n>
58860739: RXMODE_SINGLE, freq=923300000, SF=12, BW=500, CR=4/5, IH=0<\r><\n>
rxtimeout: entry: 58864327 rxtime: 58860731 entry-rxtime: 3596 now-entry: 4 rxtime-txend: 374875<\r><\n>
58864346: EV_JOIN_TXCOMPLETE: no JoinAccept<\r><\n>
And here’s what TTN shows:
If that is 4 seconds after TX it’s a second early, join delays are 5 (rx1) and 6 (rx2) seconds.
It would be useful to know how close or far away the unit is from the gateway - we can’t see the RSSI or SNR it may well be that the tracker just can’t hear the join accept.
They’re sitting right next to each other. Also tried moving the trackerd about 20’ away.
Note that the LSN50 v2 worked perfectly under same conditions.
Did you solve this problem?
Seems that I have also the same problem.
Did you solve it and how?
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1284
load:0x40078000,len:12836
load:0x40080400,len:3032
entry 0x400805e4
Wakeup was not caused by deep sleep: 0
TrackerD ,v1.4.8
EU868
TDC:1200000
BAT:4002 mV
Packet queued
97244: EV_JOINING
462509: EV_TXSTART
475058: TXMODE, freq=868100000, len=23, SF=7, BW=125, CR=4/5, IH=0
791309: RXMODE_SINGLE, freq=868100000, SF=7, BW=125, CR=4/5, IH=0
rxtimeout: entry: 791836 rxtime: 791299 entry-rxtime: 537 now-entry: 5 rxtime-txend: 312375
853808: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 868159 rxtime: 853799 entry-rxtime: 14360 now-entry: 6 rxtime-txend: 374875
868181: EV_JOIN_TXCOMPLETE: no JoinAccept
4507439: EV_TXSTART
4519992: TXMODE, freq=868500000, len=23, SF=7, BW=125, CR=4/5, IH=0
4836242: RXMODE_SINGLE, freq=868500000, SF=7, BW=125, CR=4/5, IH=0
rxtimeout: entry: 4836769 rxtime: 4836233 entry-rxtime: 536 now-entry: 6 rxtime-txend: 312375
4898742: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 4913092 rxtime: 4898733 entry-rxtime: 14359 now-entry: 6 rxtime-txend: 374875
4913113: EV_JOIN_TXCOMPLETE: no JoinAccept
8682673: EV_TXSTART
8695242: TXMODE, freq=868300000, len=23, SF=7, BW=125, CR=4/5, IH=0
9011491: RXMODE_SINGLE, freq=868300000, SF=7, BW=125, CR=4/5, IH=0
rxtimeout: entry: 9012018 rxtime: 9011482 entry-rxtime: 536 now-entry: 6 rxtime-txend: 312375
9073991: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 9088341 rxtime: 9073982 entry-rxtime: 14359 now-entry: 6 rxtime-txend: 374875
9088362: EV_JOIN_TXCOMPLETE: no JoinAccept
13627068: EV_TXSTART
13639617: TXMODE, freq=868100000, len=23, SF=8, BW=125, CR=4/5, IH=0
13959081: RXMODE_SINGLE, freq=868100000, SF=8, BW=125, CR=4/5, IH=0
rxtimeout: entry: 13959993 rxtime: 13959073 entry-rxtime: 920 now-entry: 6 rxtime-txend: 312375
14021582: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 14035932 rxtime: 14021573 entry-rxtime: 14359 now-entry: 6 rxtime-txend: 374875
14035953: EV_JOIN_TXCOMPLETE: no JoinAccept
Hello. Has anyone solved this issue? I’m having the same. My Dragion Tracker D says “no JoinAccept” but in the TTN console, it says “join accept message”. I’m using my own gateway (Raspberry PI with LoRa/GPS HAT and "Single_Chan_Pkt_Fwd application. Appreciate any help!
In my case it was no valid gateway was available.
After creating my own it worked.
I used a mikrotik industrial router with lte and Lora module.
Thanks codingbott. Well, my case seems to be different then as I have my own gateway. Maybe I try a different sensor to validate if my gateway works as expected.
And
Please search the forum to understand why what you have is not a LoRaWAN gateway, single channel packet forwarders are disruptive for the network and cause issues like you are experiencing.
A gateway, by definition, has 8 channels that can listen across multiple spreading factors. See Single Channel Packet Forwarders (SCPF) are obsolete and not supported and please bear in mind you are compromising the network for other users.
Got it, thanks. I just ordered a MikroTik LoRa8 gateway. Wasn’t aware of the SCPF not being supported. Hope this will resolve my issue.
