Hello, which IoT platform do you recommend for making a mobile app or web app for controlling lights with light controllers in class C?
Actually, we are going to control over 20 luminaires.
P.S. Maybe in the future, make a map to see the distribution of the lights and see if they are on or off
You appear to be trying to build a commercial application that exceeds the normal use of TTN via a sequence of questions with almost no prior investigation.
If you want a mobile app, how does a dashboard figure in to the equation?
If you want a web app, how does a dashboard figure in to the equation?
What is the difference between a mobile app & a web app?
Is a dashboard an IoT platform?
Can you categorise Node-RED as a dashboard?
Your topic title is a classic X-Y example - how do I build X with Y - rather than what should I use to build X with. The one thing we are not in short supply of at present is websites that help people build web & mobile apps - perhaps frequenting a few of them could help you be more specific in your questions rather than just a fishing expedition.
