Things UNO will not join TTN (US frequency plan)
My Things Gateway and Things Uno arrived today here in Canada, the “backer” editor. I’d selected “Let us decide based on your address” for the frequency plan when I ordered.
On the packing slip attached to the box there’s a handwritten “TTGW868X1” and “TTU868X1” which makes me wonder whether I received the devices for the wrong frequency plan; additionally, I was sent only a UK and EU plug adapter, so needed to use my own adapter.
However, I proceeded with the setup of the Gateway and this was problem free, and it’s showing as “connected” on the Things Network console with the “United States 915MHz” frequency plan I selected on activation.
Setting up the Things Uno, however, I’ve run into a problem.
When I first plugged in the Uno, the default sketch ran, and I saw traffic in the Traffic tab of the Things Network console every minute. The “frequency” column for this traffic was 868.
I identified the Device EUI of my Uno as outlined, and then created a TTN Application and copied and pasted the appEui and appKey into the QuickStart sketch.
I set the freqPlan to TTN_FP_US915.
When I upload the sketch, however, the join fails, and the serial monitor output is as follows:
-- STATUS
EUI: 0004A30B001BFE78
Battery: 3263
AppEUI: 70B3D57ED0009C47
DevEUI: 0004A30B001BFE78
Data Rate: 7
RX Delay 1: 1000
RX Delay 2: 2000
-- JOIN
Model: RN2483
Version: 1.0.1
Sending: mac set deveui 0004A30B001BFE78
Sending: mac set adr off
Sending: mac set appeui 70B3D57ED0009C47
Sending: mac set appkey A089BD843E502DBE3B35D37A91082891
Sending: mac save
Sending: mac set ch status 0 off
Sending: mac set ch status 1 off
Sending: mac set ch status 2 off
Sending: mac set ch status 3 off
Response is not OK: invalid_param
Sending: mac set ch status 4 off
Sending: mac set ch status 5 off
Sending: mac set ch status 6 off
Sending: mac set ch status 7 off
Sending: mac set ch status 8 on
Sending: mac set ch drrange 8 0 3
Sending: mac set ch status 9 on
Sending: mac set ch drrange 9 0 3
Sending: mac set ch status 10 on
Sending: mac set ch drrange 10 0 3
Sending: mac set ch status 11 on
Sending: mac set ch drrange 11 0 3
Sending: mac set ch status 12 on
Sending: mac set ch drrange 12 0 3
Sending: mac set ch status 13 on
Sending: mac set ch drrange 13 0 3
Sending: mac set ch status 14 on
Sending: mac set ch drrange 14 0 3
Sending: mac set ch status 15 on
Sending: mac set ch drrange 15 0 3
Sending: mac set ch status 16 off
Sending: mac set ch status 17 off
Sending: mac set ch status 18 off
Sending: mac set ch status 19 off
Sending: mac set ch status 20 off
Sending: mac set ch status 21 off
Sending: mac set ch status 22 off
Sending: mac set ch status 23 off
Sending: mac set ch status 24 off
Sending: mac set ch status 25 off
Sending: mac set ch status 26 off
Sending: mac set ch status 27 off
Sending: mac set ch status 28 off
Sending: mac set ch status 29 off
Sending: mac set ch status 30 off
Sending: mac set ch status 31 off
Sending: mac set ch status 32 off
Sending: mac set ch status 33 off
Sending: mac set ch status 34 off
Sending: mac set ch status 35 off
Sending: mac set ch status 36 off
Sending: mac set ch status 37 off
Sending: mac set ch status 38 off
Sending: mac set ch status 39 off
Sending: mac set ch status 40 off
Sending: mac set ch status 41 off
Sending: mac set ch status 42 off
Sending: mac set ch status 43 off
Sending: mac set ch status 44 off
Sending: mac set ch status 45 off
Sending: mac set ch status 46 off
Sending: mac set ch status 47 off
Sending: mac set ch status 48 off
Sending: mac set ch status 49 off
Sending: mac set ch status 50 off
Sending: mac set ch status 51 off
Sending: mac set ch status 52 off
Sending: mac set ch status 53 off
Sending: mac set ch status 54 off
Sending: mac set ch status 55 off
Sending: mac set ch status 56 off
Sending: mac set ch status 57 off
Sending: mac set ch status 58 off
Sending: mac set ch status 59 off
Sending: mac set ch status 60 off
Sending: mac set ch status 61 off
Sending: mac set ch status 62 off
Sending: mac set ch status 63 off
Sending: mac set ch status 64 off
Sending: mac set ch status 65 on
Sending: mac set ch status 66 off
Sending: mac set ch status 67 off
Sending: mac set ch status 68 off
Sending: mac set ch status 69 off
Sending: mac set ch status 70 off
Sending: mac set ch status 71 off
Sending: mac set pwridx 5
Sending: mac set retx 7
Sending: mac set dr 3
Sending: mac join otaa
Response is not OK: no_free_ch
Send join command failed
The MicroChop on my Uno is labeled RN2483.
Is it possible that I’ve got an Uno designed for the EU frequency plan paired with a Gateway that’s set for the USA frequency plan?
Hi, I’m afraid you’re right … RN2483 = EU, you should have received one with an RN2903 radio module
If the node is EU, then:
…would be weird, unless the gateway’s hardware is also EU hardware, and the selected frequency plan is somehow ignored (or errors while loading a wrong frequency plan do not stop the gateway from starting to listen on its default frequencies).
So: both your node and gateway seem to be using EU frequencies and hardware. :frowning:
You can easily remove the gateway’s white cover. What does the LoRa module state for its type? I think LG8271 would be EU. Or maybe even easier: what does http://things-gateway.local/info show for “Gateway card”?
(As an aside: nodes do not pair with a gateway. They just transmit and hope one or more gateways receive their packet and forward it to TTN.)
It turns out that I was shipping an EU Gateway and an EU Uno; they’ve now been replaced with US versions of both, and all is well.
