Hi folks,
I finally had some time to try out the Things Uno I received through the Kickstarter campaign.
Model: TTN-003-868-1.0
I followed the regular instructions:
- Registered an account,
- In the console I created an app
- Flashed the Uno with the DeviceInfo example (with the EU freq)
- Retrieved the EUI from that
- In the console registered the device
- Flashed the Uno with the SendOTAA example in which I copied the example code (and EU freq)
- But the OTAA keeps failing:
Model: RN2483
Version: 1.0.1
Sending: mac set deveui 0004A30B001C3945
Sending: mac set adr off
Sending: mac set appeui 70B3D57ED00164AB
Sending: mac set appkey DA1EFE5B9C2A01FFF7274BDDD76BCA39
Sending: mac save
Sending: mac set rx2 3 869525000
Sending: mac set ch drrange 1 0 6
Sending: mac set ch dcycle 0 799
Sending: mac set ch dcycle 1 799
Sending: mac set ch dcycle 2 799
Sending: mac set ch dcycle 3 799
Sending: mac set ch freq 3 867100000
Sending: mac set ch drrange 3 0 5
Sending: mac set ch status 3 on
Sending: mac set ch dcycle 4 799
Sending: mac set ch freq 4 867300000
Sending: mac set ch drrange 4 0 5
Sending: mac set ch status 4 on
Sending: mac set ch dcycle 5 799
Sending: mac set ch freq 5 867500000
Sending: mac set ch drrange 5 0 5
Sending: mac set ch status 5 on
Sending: mac set ch dcycle 6 799
Sending: mac set ch freq 6 867700000
Sending: mac set ch drrange 6 0 5
Sending: mac set ch status 6 on
Sending: mac set ch dcycle 7 799
Sending: mac set ch freq 7 867900000
Sending: mac set ch drrange 7 0 5
Sending: mac set ch status 7 on
Sending: mac set pwridx 1
Sending: mac set retx 7
Sending: mac set dr 5
Sending: mac join otaa
Join not accepted: denied
Check your coverage, keys and backend status.
The Things Network status seems fine.
There are no messages appearing in the Device’s Data page.
Reading through forum posts it’s probably a coverage or reception issue. So I’ve tried this at multiple locations through the City Utrecht in the Netherlands:
- At home in Overvecht,
- t’Koffieboontje next to the windmill,
- At Bar Beton Central Station
Could there be something wrong with the Things Uno? Have others successfully use it?
I found some suggestions to solder on a external antenna, but I’m hoping that won’t be necessary.
Anyone else having issues in Utrecht (Netherlands)?
