without a type-c adapter phone you can’t activate this device !
and DJI don’t supply a usb to type c adapter or cable… So I have to buy a new
phone first ? and they don’t mention that…aaaaaaaaaaaaargh 400 euro …
so to actually use it stand alone. you’ll first need one of these
next time I should read the brandnew product forum before ordering… this one is also full of bugs
The product itself feel solid and wellmade and the footage you’ll find on YouTube is indeed incredible.
But there are many, many problems to solve… to name a few :
needs to be 'activated by newer type phone
can’t be used without activation
gets to hot after 10 minutes use
dead pixel issues screen
no accessoires available (everything seems ‘preorder’
My reason is this … last year I bought the original (expensive) RPI '7 touch screen.
But, I couldn’t (without hacking) dim the back light or switch it completely on/off when not needed and when a sensor detected someone was really watching/using that screen.
Basically an always ON display… very bad for your battery
So with this little HDMI and touch screen, it should be possible to create that behaviour, when my hand is close to the screen it switches on and you see a nice menu / graph / data, want to try and build that with the python framework KIVY
Looking like micro SD card had enough in my home gateway. Do you think I could do some “Santa Clause forensic investigation” tomorrow as a (lame) excuse to climb up on the roof to recover it? Kidding… I will leave it to the 26th!!!
That said it looks like my original RAKberry Pi gateway is heading for the workbench, I shall power up my @Charles Pi Zero W design gateway as a stop-gap.
Merci Charles
How long was it running for all told? Which s/w build was installed/ any SD Card mitigation included etc…would be useful to know background and your experience.
Also did unit see any unplanned power outages during its operating time - I’ve only seen failures immediately after power outs or within a few days of…
With regard to the SD card, it has been on the roof for two winters and 1.5 summers and I am sure it wasn’t new either. Ireland so normally temperate, some wide swings in temperatures by chance in this card’s life. The packet forwarder died before, I can’t recall exactly why but I do sort of remember re-building the application using Git and Resin.io. The gateway also stopped right after a power cut/reset in one of those autumn storms. It restarted with a power cycle then but not today
