The WORKBENCH part 2
routerboard
saturdaymorning shopping… ’ that could be useful… some day :roll_eyes:
* update :sold out
x1099
x1100
Nylon Plastic Stick On PCB Spacer Standoff Locking Snap-In Posts Fixed Clips Adhesive 3mm Hole Support :woozy_face:
x1102
20pcs 20*20MM White Zip Tie Cable Wire Removable Self Adhesive Wall Holder Mount Clip/Clamp :woozy_face:
x1106
30x Electrical Cable Connectors Quick Splice Lock Wire Terminals Self Locking :woozy_face:
x1107
10pcs Quick Connect Terminal Electric Cable Wire Connector PCT-212/213/214/215 :woozy_face:
ok
uhhhhhhhhh… ok got it :sweat:
x1101
it’s alive !
indicatorthingy
Testing TPL5510…
Kicked, updated the repo, thanks for mentioning that
x1103
new angled patch cables arrived … now it fit’s in the enclosure
x1104
and continue with the 3g/4g/wifi rechargeable mobile gateway
how did @jmarcelino got all that in such a small box ? :scream:
x1110
IMG_20181015_160940 My workbench today, a tall rock in Ireland
IMG_20181015_154614
Over there, in Wales, surely one gateway? I could see the UK but my packets not finding a any hardware I didn’t own!
first tons of errors get thrown at the innocent noob user … :sweat_smile:
x1108
Today code optimisation of my Meetjestad node connected to an Honywell particle sensor. This image was captured with my Siglent scope (good suggestion on this forum) and a uCurrent Gold (eevblog).
makes the whole sequence visible :+1:
x1111
x1112
first use of new gluegun… aaaaargh :sweat:
x1116
dual voltage power unit with 4 x 12000 mA in 2S2P balanced config, output 8.4 v (dc/dc to 5 and 12v)
x1117
before mounting the cells I charge them individually to an equal value, mount the balance board and leave them balancing for a night, then discharge the pack and recharge… and finally test.
goal is 2 days working on battery’s (without sun/charging)
x1118
x1120
x1124
test GPS module
x1125
ruggedising the enclosure for outdoor use
x1123
x1113
x1114
x1115
'recycle older 4:3 d-sub monitors (the ones that you get for free :wink: ) with help of
this 1080P Hdmi Female To Vga Male With Audio Output Cable Converter Adapter C6V5
US $4.42
So a man contacts me via TTN, asks can we meet and talk LoRaWAN, drops the letters “PIR” in casual concersation and I go all @BoRRoZ!20181022_230616
…and build a PIR node to demo. My ultra low power PIR’s vanished in shipping but this should go for a while on a 18650 for demo :slight_smile:
Which ultra low power PIR’s did you order?
you can modify the 'standard PIR’s to operate @3V (and lowering the operating current)
or buy a low current one like this module (15uA!)
but don’t forget… low power comes with a price… detection distance
@fewi The units I purchased but which were lost were the 15uA PIR’s that @BoRRoZ links to just above here ^^^
G
Sadly that vendor does not ship to UK but this one does & has a few left in stock. @GryKyo …u in Eire? Maybe that allowed shipment or may be why lost?
@Jeff-UK - Our postal service received/scanned a package originating in China but it never tracked any further . When I contacted post office they said they could only talk to sender… yeah, good luck!!!
We have a “pre-backstop” arrangement already in place here in South of Irleand. Several logistics operators will receive goods north of the border and next-day to parcel-depot lockers in the south. About £3.50 for the luxury but can be 10x that for shipping or some cases where no option outside UK is offered.
G
x1127
today will try to finish the wiring :roll_eyes:
x1128
thinking about howto easy mount the enclosure later without drilling holes , I had this idea of glueing some really strong magnets inside.
be warned… it hurts when they suddenly stick together with some skin in between :sob:
anyway… these are the magnets I used
magnets
x1129
