I’m having problems with activating The Things Uno.
I’m following the ‘Quick Start’ steps at:
https://www.thethingsnetwork.org/docs/devices/uno/quick-start/index.html
I’ve got the Device EUI from the Uno by uploading a program to it and reading the output via the serial monitor in Arduino IDE.
I’ve added an application and my Uno device using the Device EUI from the board in the ‘CONSOLE’ section of The Things Network.
My problem is activating the device.
Instead of the device joining, I’m getting an error after a short delay each time:
Sending: mac join otaa
Join not accepted: denied
Check your coverage, keys and backend status.
The Things Network console status for the Uno device is ‘never seen’.
I wondered if the problem is caused by the gateway, but I have a different device, a Elsys ERS and that’s still working fine. FYI, the gateway is not my own. Instead it’s a community one installed by a local council in Norwich, Norfolk, UK.
Please find below the code from the IDE and a log from the serial monitor. I’ve changed the actual appKey for the forum post to CUTANDPASTED. The one used in the running code is the one from the console.
Any help would be very welcome. Thanks.
— IDE code —
#include <TheThingsNetwork.h>
const char *appEui = "70B3D57ED0040481";
const char *appKey = "CUTANDPASTEDFROMSOURCE";
#define loraSerial Serial1
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
#define freqPlan TTN_FP_EU868
TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
void setup()
loraSerial.begin(57600);
debugSerial.begin(9600);
// Initialize LED output pin
pinMode(LED_BUILTIN, OUTPUT);
// Wait a maximum of 10s for Serial Monitor
while (!debugSerial && millis() < 10000);
debugSerial.println("-- STATUS");
ttn.showStatus();
debugSerial.println("-- JOIN");
ttn.join(appEui, appKey);
void loop()
— LOG —
-- STATUS
EUI: 0004A30B001C1524
Battery: 3243
AppEUI: 70B3D57ED0040481
DevEUI: 0004A30B001C1524
Data Rate: 5
RX Delay 1: 1000
RX Delay 2: 2000
-- JOIN
Model: RN2483
Version: 1.0.1
Sending: mac set deveui 0004A30B001C1524
Sending: mac set adr off
Sending: mac set appeui 70B3D57ED0040481
Sending: mac set appkey CUTANDPASTEDFROMSOURCE
Sending: mac save
Sending: mac set rx2 3 869525000
Sending: mac set ch drrange 1 0 6
Sending: mac set ch dcycle 0 799
Sending: mac set ch dcycle 1 799
Sending: mac set ch dcycle 2 799
Sending: mac set ch dcycle 3 799
Sending: mac set ch freq 3 867100000
Sending: mac set ch drrange 3 0 5
Sending: mac set ch status 3 on
Sending: mac set ch dcycle 4 799
Sending: mac set ch freq 4 867300000
Sending: mac set ch drrange 4 0 5
Sending: mac set ch status 4 on
Sending: mac set ch dcycle 5 799
Sending: mac set ch freq 5 867500000
Sending: mac set ch drrange 5 0 5
Sending: mac set ch status 5 on
Sending: mac set ch dcycle 6 799
Sending: mac set ch freq 6 867700000
Sending: mac set ch drrange 6 0 5
Sending: mac set ch status 6 on
Sending: mac set ch dcycle 7 799
Sending: mac set ch freq 7 867900000
Sending: mac set ch drrange 7 0 5
Sending: mac set ch status 7 on
Sending: mac set pwridx 1
Sending: mac set retx 7
Sending: mac set dr 5
Response is not OK: no_free_ch
Send join command failed
