I’m trying to setup my the things outdoor gateway via a VPN.
Uploading the vpn config file doesnt do anything. The VPN log stays empty.
Was anoyone here successfull with a similar venture? If so, how?
Apparently the firmware version that shipped with my TTOG was glitched.
I updated to the latest version via: https://connectedthings.store/gb/lorawan-gateways/outdoor-lorawan-gateways/the-things-outdoor-gateway-868-mhz.html (right side of the site)
and now everything is working fine
Hi, i am currently trying to enable remote management for this Gateway.
We thought about using Ngrok (https://ngrok.com/) and install the service on the Gateway.
Why did you choose to use VPN over reverse SSH?
Is it more easy/reliable to use? Do you prefer it because it is built-in?
Can you quickly tell me, how you did setup the backend (VPN Server)?
Thanks for your help!
Hello!
The reason I went for the vpn connection is, like you said, because it was already there in the GUI.
We run an openvpn server on our production server so I just generated a certificate for the gateway and it connected straight away, after updating the firmware.
