While trying to set up The Things Outdoor Gateway using https://www.thethingsnetwork.org/docs/gateways/thethingsoutdoor/ it seems the only port open on the unit is ssh. admin/admin does not work and I am unable to find the default user/pass for this unit. What am I missing here.
Where did you buy that gateway ?
okā¦ Iām a bit supprised ā¦ you must be one of the first who owns one
The units look super solid and I am desperate to get it working
Me too - thought these were going out through RS and have been monitoring ready to buy a couple of test units!
wonder how CT got them - and who else has access to them before RS release - if there is another wholesaler/distributor with stock would like to know so I can grab one to evalā¦
Have you asked CT if they sold you the unit?!
Hey
I can confirm we have VERY limited stocks of the outdoor gateway at Connected Things, I think these are some of the first available, fresh from China. Weāve been working with TTN/TTI to get them out to the first folk that got in touch with TTI to register interest, before they hit general circulation. Donāt worry @Jeff-UK, we didnāt do anything sneaky to get them!
We hope to have more from the next (much bigger) batch that is coming soon.
In the meantime, yes, I can confirm the problem @rocketfarm has is the same on the test unit I have. Weāre working with TTI to sort this out. All part of the fun of being an early adopter!
Cheers,
Al
Would have āregistered interestā with TTN/TTI if I had knownā¦message was ārelease through RSā so was waiting patiently! Well done for stealing a march on the market though!
Hi all
So some good news, we have a workaround for the problems with the web GUI so itās possible to get the gateways up and running.
If youāve ordered a gateway from Connected Things Store/Sensational Systems then you should have just received an email from me with a guide. If you didnāt get one then give me a shout and Iāll send it over to you.
I have two, just beginning the set up this weekend. Build quality is vgood and the 16 channels / geolocation and 3/4G backhaul will certainly disrupt the OGW market in a positive way.
Will post a set blog when I am up and running.
I didnāt get one, can you send it to me please
Hi Rainer
For the latest gateways you should be able to follow the instructions at the bottom of this page https://connectedthings.store/gb/lorawan-gateways/the-things-outdoor-gateway-868-mhz.html
And then the TTN docs here https://www.thethingsnetwork.org/docs/gateways/thethingsoutdoor/
Does that work for you?
No guide with mine either (US version). I did have it running briefly but now the log says āERROR: [main] failed to start the concentratorā and no packets get sent.
