You certainly can connect from Africa to the EU cluster, 100’s of gateways down south and they all work to the EU cluster.
Big thing you need to ensure is low latency connection, you can use the links below to check. The TTN cluster is on the AWS - Ireland eu-west-1, if I recall correctly.
