Hi!
When hitting: https://nam1.cloud.thethings.network/api/v3/as/applications/app-id/packages/storage/uplink_message?limit=2
I receive the following body:
{"result":{"end_device_ids":{"device_id":"t-beam-11-weather-station","application_ids":{"application_id":"apartment-weather-station"},"dev_eui":"000479C57080D2EE","dev_addr":"260C5681"},"received_at":"2021-08-29T00:01:04.680953136Z","uplink_message":{"f_port":1,"f_cnt":429,"frm_payload":"/3//fw==","decoded_payload":{"message":{"degreesC":99.951171875,"humidity":99.951171875}},"rx_metadata":[{"gateway_ids":{"gateway_id":"a84041ffff1ede24tomas","eui":"A84041FFFF1EDE24"},"timestamp":1356767240,"rssi":-50,"channel_rssi":-50,"snr":12.8,"channel_index":4}],"settings":{"data_rate":{"lora":{"bandwidth":125000,"spreading_factor":10}},"coding_rate":"4/5","frequency":"904700000","timestamp":1356767240},"received_at":"2021-08-29T00:01:04.465791633Z","consumed_airtime":"0.329728s","network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"ttn-nam1"}}}}
{"result":{"end_device_ids":{"device_id":"t-beam-11-weather-station","application_ids":{"application_id":"apartment-weather-station"},"dev_eui":"000479C57080D2EE","dev_addr":"260C5681"},"received_at":"2021-08-29T00:02:23.959239182Z","uplink_message":{"f_port":1,"f_cnt":432,"frm_payload":"/3//fw==","decoded_payload":{"message":{"degreesC":99.951171875,"humidity":99.951171875}},"rx_metadata":[{"gateway_ids":{"gateway_id":"a84041ffff1ede24tomas","eui":"A84041FFFF1EDE24"},"timestamp":1436054746,"rssi":-107,"channel_rssi":-107,"snr":-8,"channel_index":6}],"settings":{"data_rate":{"lora":{"bandwidth":125000,"spreading_factor":10}},"coding_rate":"4/5","frequency":"905100000","timestamp":1436054746},"received_at":"2021-08-29T00:02:23.744378167Z","consumed_airtime":"0.329728s","network_ids":{"net_id":"000013","tenant_id":"ttn","cluster_id":"ttn-nam1"}}}}
As you can see between every {"result": [...]}
there are no commas and no brackets surrounding it, so it fails to comply with JSON standard and it fails when trying to parse it as is.
