On Saturday, I managed to get the TTN working but today I couldn´t the led was blinking green. i read the docs and it says : Conectado a WiFi, estableciendo conexión a LNS / Configurando radio.
All my TTIGs are still offline.
The update on the status website says that three hours ago 50% of the gateways have already reconnected and the rest comes online gradually. Is the fix really working for all gateways?
Hi all,
the problem persists on the disconnected gateway …
I’ve made some power cycles and also some reconnects to my WLAN,
but LED is blinking fast green since Dec 15.
So I digged out a second TTIG, which was connected some days ago on another place.
I reconfigured it … and, luckily its working fine …
Since reconfiguring the other TTIG doesn’t help, is factory resetting it (pressing the RESET button for more then 5 sec) an option ? Or could this action brick the device, since this wipes out LNS credentials?
Can you please provide your EUIs so that we can take a look?
No this will not brick the device. A reset always makes the gateway connect to the boot CUPS server, where proper redirection is set up.
I’ve tried a Reset of the faulty GW, but no effect
The EUI of the “faulty” GW is: eui-58a0cbfffe80130d
The EUI of the “good” GW is: eui-58a0cbfffe800ca8
Same problem as everyone else.
My TTIG runs for several months now without any problem and stopped working correctly yesterday around 11 am of my time, 10 am GMT.
Right now the green LED is blinking rapdily.
The ID is eui-58a0cbfffe801b5e.
