The Things Indoor Gateway (TTIG) Migration V2 to V3
I have a TTIG model TMBH100915 connected and working on the V2 network.
These instructions were followed to migrate to V3:
https://www.thethingsnetwork.org/docs/the-things-stack/migrate-to-v3/
After following the instructions, the gateway shows that it is connected to V2 and not connected to V3.
To be fair, I did change the Address in the Console rather than in the JSON because downloading the JSON and changing it in my downloads folder seemed pointless (unless there is some quantum entanglement).
Also, the instructions do no seem to support any location other than Europe but I am in North America. Using eu1.cloud.thethings.network as instructed did not work. Using nam1.cloud.thethings.network did not work either.
Can anyone provide alternative instructions?
Thank you,
Mark
Nope. Search the forum for information on the status of TTIG.
TTI will push an update out when the TTIG can be installed on v3.
Do not change or delete anything on any console lest it stops working on v2 (which will pass on uplinks to v3 just fine) and you end up preventing it from working on v3.
In the meanwhile, you could post an issue on GitHub for the v3 docs to add a warning about trying to move a TTIG over.
