Without Access to V2 you can flash the device also. Downside from the sd-card solution is that you have to keep using sd card forever.
Could you explain what you mean with “ad solution”.
Right now, ttn3 shows Gateway as connected, but no messages reaching ttn3, also the gateway claims to have forwards X- Packages (increases, when sending from device), but they do not show up in console.
Its a typo where my phone interfered with my typing. (I hate auto correct on smartphones)
I meant SD-card solution.
Your problem was mentioned before on the forum. As I never suffered from that problem if have not investigated on it so I cannot help you with that.
Ah ok. Thanks for your hint, now its working. The tenant should not be used:
Happy to be of help.
