How to Build a Portable, Accurate, Low Cost, Open Source Air Particle Counter
verbied āonveiligeā IOT apparaten (stemmachines ?)
Connecting students to the āInternet of Thingsā
IBM Introduces Industry-Specific-Watson IOT Services
Obama Administration Lays Out Lengthy List of IoT Security Guidelines
http://lora-node.readthedocs.io/en/latest/
TheThingsNetwork meets scriptr
open-source implementation of the LoRa CSS PHY
Building A LoRa PHY
We are glad to announce a preview of Lua RTOS for ESP32. Lua RTOS is the main-core of the Whitecat ecosystem, that is being developed by a team of engineers, educators and living lab designers, designed for build Internet Of Things networks in an easy way.
There are many things to do, but for the moment the following is available:
- Lua 5.3.2 interpreter at the top
- Lua Threads
- LMIC LoRa WAN stack !
- GPIO driver
- SPI driver
- SD Card driver
- FAT files ystem
- SPIFFS file system
- TFT ST7735 driver
Semtech announced a new concentrator chip - SX1308 - to power sub $100 gateways.
Interesting that chip footprint is the same as the SX1301 so existing gateway designs - like the TTN gateway - could be compatible with minor or no changes. Like its parent the SX1308 also seems to be under NDA, data sheet available only to paying LoRa Alliance members and chips only available after passing the initiation ritual in Grenoble.
Espressif Licenses and Deploys CEVA Bluetooth in ESP32.
Bluetooth 5 specification officially announced with 4x range, 2x speed and 8x broadcasting message capacity
https://www.bluetooth.com/specifications/adopted-specifications
Nordic Semiconductor-powered Bluetooth low energy programmable sensors and actuators
teach children basic programming and wireless technology skills.
Archos announes the availability of its PicoWAN solution.
This is a solution compatible with LoRaWAN node. The pico GW + one āpush button nodeā is availlable at ā¬19.90
https://www.archos.com/en/products/objects/chome/pwpack/index.html
The gateway will likely be unable to participate to TTN, but interesting price point. Same collaborative deployment model as TTN, for residential use.
Hmmmm I feel a little bit of hacking . . . . .
But that would be a nice home GW design
Ordered a couple. Preparing the screwdrivers
Draguino has launched an Indiegogo campain for LoRa kit. https://www.indiegogo.com/projects/lora-kit-for-iot-applications#/
They claim some nodes and gateway, but is only single channel gateway.
