I have one mounted on the base of my TV antenna pole above my house. It is in an enclosure approx 200 x 150 x 80 with no additional heating or cooling using a single PoE cable to bring power and data to the gateway. It runs sweet in the Irish climate which is temperate, my house being close to the gulf stream zone never really getting too warm or cold. It has not been tested too hard yet as we are only feeling a little frost this week but solid as a rock so far, on line for about 1 month with only a few restarts for maintenance, internet re-connects etc. FWIW, it runs Kersingās code on resin.io which just works.
Just to clear things with RSSI.
I needed to reboot my gateway today.
And now I see some nodes with lower RSSI
So I was wrong about gw not receiving lower then -115.
The RAK831 Datasheet (in addition to the SPI pins) lists the following pins:
LNA_EN_A
RADIO_EN_A
PA_G8
RADIO_EN_B
PA_G16
PA_EN_A
RADIO_RST
and 5 SX1301 GPIO ports: GPIO0 ā¦ GPIO4 (each with a corresponding status LED).
Are any of these pins used by the gateway software or is only the SPI interface used?
Would it be of any use to connect these (non-SPI) pins to the host controller (RPi)?
(Just asking because these pins are wired on RAKās Raspberry Converter Board.)
Iām still waiting for my RAK831 board and not sure if GPS is required for the gateway or not (and which would be the best converter board to use with RPi 2/3).
RAK831 has an IPEX connector for connecting GPS time pulse.
I see no other connections (usually serial Rx/Tx) for connecting a GPS to the board.
Is only the GPS time pulse used for the gateway, but not any location data?
Or does the gateway software support location data and does the GPS have to be connected to the Rx/Tx pins of the (RPi) host?
Concentrators just take in the PPS. It is the packet forwarder running on the host PC (e.g. the RPi) that can be made to parse the NMEA data, but I donāt know if any packet forwarder supports this out of the box.
RAK831 is available in several combinations.
When ordering I unfortunately overlooked this specific combination: RAK831 + Raspberry Pi converter board (not including the Pi itself).
The photo shows GPS time pulse cable soldered onto the converter board. On the actual version it is connected with an IPEX connector (located near the reset switch).
I assume to connect the GPS module RX/TX pins to Raspberry Pi pins to make possible to communicate with the GPS and read location data. The jumper construction is for making the connection optional I guess.
(I have ordered a board but have not yet received it.)
For older versions of the converter board without RX/TX wired it will be relative easy to solder two wires from the GPS module to the 40-pin Raspberry Pi connector (if needed).
Ahh, ok, makes sense, since the PPS signal is for the RAK831, and if want to access GPS data from the RPI some connection needs to be made. Probably this.
I just got my rak831 with the vendor supplied raspberry pi 3 and the interface board. However it seems that the reset pin is not routed to the same GPIO port as is used on the ttn-zurich build. Couldnāt find out if it is routed to a different pin or not at allā¦ Resetting it manually using the switch on the interface board gets a little bit irritant.
Quick question to all those in this conversation who have attempted to set up and mount the RAK831 dev kit as a functioning gateway (i.e. high up with an external antenna or installed outside within a suitable housing).
How robust is the hardware?
I am keen to order the RAK831 as the price is great, but I am worried about the need to constantly maintain it (compared with an out of the box MatchX or equivalent).
I have a simple RPi + RAK831 using a Chinese antenna all mounted on my TV antenna pole in the east of Ireland. The climate here is ātemperateā so temperature ranges little by comparison to continental Europe for example, maybe -6 to 25C max range in the main. Right now I can see that the Piās CPU is at 30.4C. It is a rainy climate so I think skill in weatherproofing will be more important than temperature tolerance of the concentrator board.
The setup uses PoE injected at 19Vdc beside a small switch in my loft then regulated to 5Vdc beside the gateway. Everything is housed in a IP67 plastic box which should have enough volume and surface area not to overheat in our summer. So far using @kersingās uper easy to setup packet forwarder (resin.io) with 100% reliability and a great console to monitor/manage the gateway.
