The BIG and SMALL ANTENNA topic part 1
well, I assume that the GP antenna is 0 dBd. The GP antenna is held as reference.
Out of curiosity, what was the measurement methodology ?
I used e GTem cel and measured 3 axis. The figures presented are only the most relevant axis.
This setup produces a good indication.
It is better to perform TRP measurements or a tradtional antenna gain measurement on a OAT.
Thank you very much for the answer… but sorry that didn’t make any sense to me, and google seems to fail helping me there.
May I ask you - or anyone who knows - to provide some link or pointer about this ?
GTem cel: https://en.wikipedia.org/wiki/GTEM_cell
OAT: http://www.compliance-club.com/archive/old_archive/020312.htm
Just wondering because this topic’s title casing and the images in the first post seem to contradict:
Is this the “BIG ANTENNA” topic or is this the BIG “ANTENNA topic” ? :blush:
the idea is everything about LoRa antennas … BIG and small :sunglasses:
Getting 7.5km using the manufacturer provided long-duck antenna with a Laird RG168 gateway.
Anybody know what can we expect if we install something more like this?
http://www.webb.co.za/storage/files/WEBB_PROX_ANTENNA.pdf
My Procom CXL900-868 arrived.
IMG_20171214_185642
It’s bigger than expected :open_mouth: .
Said the actress to the bishop :wink:
VERY GOOD! THAT is a good quality antenna. :clap::clap:
MAX. POWER 100 W so no problem :wink:
Interesting article on building and using cantennas (directional).
anyone tried or heard about this one?
http://www.delock.de/produkte/H/89583/merkmale.html
it’s in the 30€ range around here, guess i gotta give it a try for my TTN gateway…
looks fine to me :sunglasses:
We just inspected the “Antenna collinear 868 Mhz 869 mhz LORAWAN LORA great gain SDR USB smart grid” from https://www.ebay.com/itm/302598573188
Interior:
afbeelding
Bottom coil:
afbeelding
Top coil
afbeelding
Measurements will follow.
I have seen a discussion before about the collineair DiY antenna :flushed: from @lex_ph2lb
Look forward to your results as I was just about to order one, will hold off for now
I am having good results at the moment with the DIY 1/4 wave GPA.
Would it be possible to compare your measurements to this one?
We are considering antenna gain measurements at the moment.
The idea was proposed earlier on this forum.
Is it not possible to come up with a top ten list of antennas for under 100 euros , we seem to never pin this down to which is the best for lorawan and in what order
