The BARGAIN basement part 6
found an interesting bargain you like to share ?
this is the central place where you can link tips about bargains.
(diy electronics components, tools, gateways, chips, antenna’s, cables, kits, measuring equipment, sensors, tools, lorawan related things)
The BARGAIN basement part 1
The BARGAIN basement part 2
The BARGAIN basement part 3
The BARGAIN basement part 4
The BARGAIN basement part 5
this is a user topic, if you want to promote your commercial products your welcome in
4ghzspectrum
mc404
screwyou
pctjuh
reichtelt
rfm95w
Particle%20Squared
Particle Squared, here’s what’s on board:
Particulate Sensing
The most important sensor is the Honeywell HPMA115S0 dust sensor (available as a purchase option). This sensor counts the concentration of potentially harmful particulates in the air. It can detect both large particles 10µm in diameter and smaller ones less than 2.5µm in diameter. These readings are known as PM10 and PM2.5 respectively.
Sensing Volatile Compounds
Second to that, is the AMS CCS811. This senses volatile organic compounds and eC02. These types of readings are useful in places where there may be combustion. (Think stoves, furnaces, etc) It can act as an early warning mechanism. That way you stay safe, happy and healthy!
Temperature and Humidity
Finally, the Silicon Labs Si7021 temperature and humidity sensor. These readings can be used on their own. Additionally they’re used by the CCS811 to compute an accurate TVOC and C02.
hoofdbrilding
Is this any useful for soldering or does the object need to be very close (few cm) to the lens?
(Which would make it also very hard with both eyes).
I’ll tell you in a couple of weeks :wink:
Comment from my side: This one did not work for me. I would not recommend it.
’ watch marktplaats ’ :rofl:
Where does it fail? Why do you not recommend it?
I wear glasses and the thing cannot compensate for that. Also even I try to wear it instead of my glasses it does not fit comfortably. The lenses are poor quality. The magnification is extreme. While not producing a sharp image. And last: the opening angle at which i see trough the lenses is so small I cannot work with it.
28%20PM
blitzwolf
44%20PM
rak4260
Digital%20Caliper
