The BARGAIN basement part 3
€136,00 incl. shipping
Looks like this one is less expensive…
ok… how much cheaper ?
110.74€ (in 2 days) + shipping (6.91€ for BE) makes 117.65€, so 18.35€ cheaper – I though it was significant enough to mention it…
and your absolutely right :wink:
any link where to buy in the EU /UK to avoid possible import taxes ?
btw i’ve read that some units break down very fast (cheap, they are working but bad manufactured) so buy from a shop with a return policy !
https://sale.aliexpress.com/__pc/7thanniversary.htm
I got on average 20% discount on electronics I had on my wish list. There also appears to be a discount on e.g. the RAK831, although I don’t recall if the original price was €163 :thinking: .
Wrong $tore.
I wonder if RAK Wireless has two stores on AliExpress now, because searching for RAK stuff (e.g. RAK831) - since a month at least - only comes up with a seller called ’Smile with Me’. I guess their smiling is more a case of [sarcasm] laughing at you [/sarcasm] because they charge you 50+% higher prices.
Yes, 50+% higher prices! (Mentioned before here: The hard RAK831 cafe part 2)
The RAK Wireless store does not show up in searches anymore, strange and not as expected.
For a normally priced RAK831 check:
https://www.aliexpress.com/store/product/RAK831-LoRa-LoRaWAN-Gateway-Module-433-868-915MHz-base-on-SX1301-Wireless-Spread-Spectrum-Transmission-range/2805180_32832894046.html
(Also mentioned here: The hard RAK831 cafe part 2)
The URL for ’RAK Wireless Module Shop’ on AliExpress is:
https://www.aliexpress.com/store/2805180
Note: Unfortunately the ‘RAK Wireless Module Shop’ appears not to participate in any AliExpress discount promotions. But still way cheaper than a discounted price from ‘Smile with Me’ with ‘free’ shipping.
You may also be interested in the RF-in / RF-out 2 socket version.
Guess you can meter the performance of antenna in-circuit with this tool?
https://de.aliexpress.com/item/New-Arrival-Best-quality-N1201SA-UV-RF-GSM-Antenna-Analyzer-Frequency-Test-range-140mhz-2700mhz-resistance/32759915213.html
new 2018 model… a little more bells and whistles but also almost double the price … but nice.
however I think I go for the cheapest one… using it only a few times a year…
if it’s your job/business I would have a look at this model:
EUR 730.00 incl. shipping
rfsolutions
x757
nice ridgid low loss cable assembly in TTN colour
US $4.79 incl. shipping
Sometimes you really do need to check the RF power output of the devices you are working with. This little unit works well. Needs to be used with an atennuator, but you can program in the attenuator value and get a power output direct in dBm.
power%20meter
deal3
A 3D printed case would be great …
  • I wonder if such a power meter really works with a chirp-based spread-spectrum modulation ?
    big chance that if you connect a node you don’t have a readout
I see no differance in reported power between an FM tone sent in direct mode versus a LoRa packet at SF12 on that power meter.
The issue with packets is that they are normally too short to to get an indication on RF power meters.
But that is not really a problem, if you set up a test LoRa device to send a long packet at SF12, you can check its 10dBm say, then hook up to something capable of doing peak readings for packets, such as a cheap SDR as spectrum analyser. You then know what the SDR indication is for a geniune 10dBm.
exactly… the device you’ve mentioned above is capable of that ?
No, that device has no peak hold capability.
Checked my soldering skills with my new 10euro microscope…
USB microscope
IMG_3027
Not to bad;
36
Nice addition to the tools of the trade.
