found an interesting bargain you like to share ?
this is the central place where you can link tips about bargains.
(diy electronics components, tools, gateways, chips, antenna’s, cables, kits, measuring equipment, sensors, lora related things)
So the Chinese 32u4 node with Li charge is now offered with two flavours of antenna costing < €1 per antenna. Before we go mad buying China again can somebody give an opinion on the antennas?
funny thing is… both antennas have an IPX connector which is not available on that board.
so you have to cut of that connector and solder the cable direct on the RFM95.
I would prefer the coil one… but a little piece of wire will do to
Actually I made that post related to a SX1276 based module, which seems to be released freshly.
The other and cheaper modules which are widely available are based on SX1278 and support only 434 MHz, not 868/915 MHz as the one I mentioned.
Newer modules are usually more expensive and price tend to go down as production increases.
@DeuxVis if you have cheaper links for the ESP32 / 868 MHz, feel free to post.
