Testers for provisioning Kerlink Wirnet Station on V3 wanted
From Slack, last week:
@roman 2019-12-20 1:29 AM
Hello everyone, we are currently working on a provisioning script for Kerlink Wirnet Station gateway. It would be extremely helpful if anyone could test it:
You need a:
  1. Running v3 stack (latest master - currently 3e2a02b31bab5bd253ad8c7766bf6b0540cab98b , if using Docker - thethingsnetwork/lorawan-stack-dev:3e2a02b31bab5bd253ad8c7766bf6b0540cab98b )
  2. Kerlink Wirnet Station gateway registered at (1.)
  3. Gateway info right API key at (1.)
Once you have that:
curl -sL https://raw.githubusercontent.com/TheThingsNetwork/kerlink-station-firmware/87ceb43c292408f68040a139199d27e783783be3/provision.sh | bash -s -- '192.168.4.155' '[thethings.example.com](http://thethings.example.com/)' 'example-gtw' 'NNSXS.GTSZYGHE4NBR4XJZHJWEEMLXWYIFHEYZ4WR7UAI.YAT3OFLWLUVGQ45YYXSNS7HTVTFALWYSXK6YLJ6BDUNBPJMRH3UQ'
Where:
  • 192.168.4.155 is the gateway IP
  • thethings.example.com is the running stack address
  • example-gtw is the registered gateway ID
  • NNSXS.GTSZYGHE4NBR4XJZHJWEEMLXWYIFHEYZ4WR7UAI.YAT3OFLWLUVGQ45YYXSNS7HTVTFALWYSXK6YLJ6BDUNBPJMRH3UQ is the API key
The script will:
  1. update firmware to 3.6 if it is lower than that
  2. install CPF if it’s not installed
  3. configure lorad and lorafwd by replacing the lorad.json and lorafwd.toml by a symlink to pushed config. The old configs will, as per default ln implemetation on the gateway moved to lorad.json.old and lorafwd.toml.old respectively.
Please see relevant PRs:
Any feedback is really welcome!
NOTE: I suggest not piping the script directly into bash like this (ever, really), but rather downloading the script, reading it and then executing if you’re happy with what it does!
Also from Slack, today:
@htdvisser 2019-12-23 9:19 AM
We’re still working on documentation for connecting gateways to The Things Stack. See Document connecting popular gateways · Issue #1140 · TheThingsNetwork/lorawan-stack · GitHub for more details
Thank you, Arjan!
Just wanted to mention that the documentation is now merged to master of lorawan-stack (since 3e2a02b31bab5bd253ad8c7766bf6b0540cab98b) and is available at https://github.com/TheThingsNetwork/lorawan-stack/blob/master/doc/content/guides/connecting-gateways/kerlinkwirnet/_index.md, so please use latest master of both repositories. I have fixed the references in your post.
This topic was automatically closed after 30 days. New replies are no longer allowed.
