Test Node Suggestion for North America
I am just starting out testing a IoT network. I bought the RAK 7249 Gateway. I am looking for an end device to do distance testing. The TTN node does not seem to be available.
Can anyone suggest a North American compatible device that I can connect? Something simple that does not require programming skills.
Thank-you
If you don’t want to do any programming I would recommend a Field Tester.
If you can do a little bit programming I would recommend a TTGO T-beam and TTNmapper.
Or use a node and the TTNmapper -APP.
A good one I use often is the : Test LoRaWAN network coverage | Adeunis
But a little bit program is also a good learning curve.
