I am trying to connect my Tektelic Kona Macro Gateway to publish the sensor messages on AWS IoT.
I use a raspberry Pi to host the server using HTTP Integration at IP 0.0.0.0 and some Port eg: 10023
I can see on the AWS IoT monitoring page that there is a connection whenever I start the code on my Raspberry Pi. but I do not see any payloads coming through the Gateway to the AWS IoT on the topic I mention on my raspberry Pi configuration. However, I do see payloads of my sensors on the Tektlic webpage. This suggests that my sensors do send a payload and are received on the gateway
Has anyone configured their LoRa Gateway to connect to AWS IoT core?
