Tago Downlink issue - Payload changed
Hi, Looking for anyone who can help on what seems to be a silly issue, but I am stuck.
I am using TagoIO connected to TTI private network to control a Milesight UC1114 Remote IO device.
When sending downlink commands, I can message from TTI without issue. eg 090100ff closes one of the relay switches.
When I try and do the same thing from Tago to TTI, the json message seems ok (I get “frm_payload”: “090100ff”,) however the actual downlink payload is “D3DD35D347DF” which obviously is ignored by device.
Can anyone point me in the right directions to fix this?
Regards
Dayne
“name”: “as.down.data.forward”,
“time”: “2021-04-05T15:04:37.043648943Z”,
“identifiers”: [
“device_ids”: {
“device_id”: “insideuc1114”,
“application_ids”: {
“application_id”: “canso-test”
“data”: {
@type”: “type.googleapis.com/ttn.lorawan.v3.ApplicationDownlink”,
“f_port”: 1,
“priority”: “NORMAL”,
“correlation_ids”: [
“as:downlink:xxxxxxx”
“as:downlink:xxxxxxxxx”
“origin”: “ip-10-22-7-252.us-west-1.compute.internal”,
“context”: {
“tenant-id”: “xxxxxx”
“visibility”: {
“rights”: [
“RIGHT_APPLICATION_TRAFFIC_READ”
“authentication”: {
“type”: “Bearer”,
“token_type”: “APIKey”,
“token_id”: “xxxxx”
“remote_ip”: “100.25.118.118”,
“user_agent”: “axios/0.20.0”,
“unique_id”: “xxxxxxxx”
  • rrow_downward
09:04:37
Successfully scheduled data downlink for transmission on Gateway Server
DevAddr
2609D304
  • arrow_downward
09:04:37
Schedule data downlink for transmission on Gateway Server
DevAddr
2609D304
FPort
1
MAC payload
ABC5DB393B86
  • arrow_downward
09:04:37
Forward downlink data message
FPort
1
Payload
D3DD35D347DF
  • arrow_downward
09:04:37
Receive downlink data message
FPort
1
Payload
D3DD35D347DF
Would you consider formatting your message for readability?
Yes, for sure,
I have separated items to make clearer, but suspect you are referring to different formatting. Can you advise what you are looking for in terms of formatting?
Dayne
Regards
Dayne
Json received by TTI
“identifiers”: [
“device_ids”: {
“data”: {
“f_port”: 1,
“context”: {
“visibility”: {
“rights”: [
“authentication”: {
“type”: “Bearer”,
“token_id”: “xxxxx”
Downlink message from TTI data browser
  • rrow_downward
09:04:37
DevAddr
2609D304
  • arrow_downward
09:04:37
DevAddr
2609D304
FPort
1
MAC payload
ABC5DB393B86
  • arrow_downward
09:04:37
FPort
1
Payload
D3DD35D347DF
  • arrow_downward
09:04:37
FPort
1
Payload
D3DD35D347DF
Did you even attempt to read message I linked to?
No, I was reading off my phone and didn’t see, I will have a look. Sorry about that.
btw, the rudeness I see in replies including this one is putting a lot of people off this board.
Would you care to explain? You get a polite request to format your post for readability, repost essentially the same message and are surprised when you get a terse reply?
Please when making statements regarding a lot of people either substantiate or refrain from making that claim. If you consider a reply rude, which does happen more often in electronic communication, just say so. Don’t involve vague third parties.
Here is my attempt at formatting. Not sure it meets the standards.
Regards
Dayne
“identifiers”: [
“device_ids”: {
“data”: {
“@type”: “[type.googleapis.com/ttn.lorawan.v3.ApplicationDownlink](http://type.googleapis.com/ttn.lorawan.v3.ApplicationDownlink)”,
“f_port”: 1,
“context”: {
“visibility”: {
“rights”: [
“authentication”: {
“type”: “Bearer”,
“token_id”: “xxxxx”
  • List item
09:04:37:Successfully scheduled data downlink for transmission on Gateway Server:DevAddr:2609D304
  • List item
09:04:37:Schedule data downlink for transmission on Gateway Server:DevAddr:2609D304:FPort:1:MAC payload:ABC5DB393B86
  • List item
09:04:37:Forward downlink data message:FPort:1:Payload:D3DD35D347DF
