We’d like to visualise the coverage of our gateway using ttnmaper.org and a t-beam node with reference :T22_V10 20191212 which includes an SX1262 radio.
I’m still unable to adapt lmic-node-gps tracker or LMIC-node
Is there a suitable library in 2023, and if not, how should I go about it ? (I’ve been looking for a long time, and my incompetence keeps leading me from failure to failure
(as for example with the advice based on the Lacuna library …)
Hi Tix and welcome back. LMIC does indeed not support SX126X chips, but there’s a contender upcoming…
If you can wait for another 2~4 weeks or something like that, your patience will hopefully be rewarded after all!
But maybe others can suggest something in the meantime.
I think that once it’s available and open for testing and/or actual use, there will be no problem for you to find it here. Check back once a week and you’ll find it quickly. We’re doing it Harry Potter style until then… must not be named
