I use sucessfully a SX1276 chip connected to a ESP32 dev board, everything works fine.
I am using Lora.h library from Sandeep Mystry.
Reset pin of SX1276 is connected to pin DIO14, as i found in an exemple.
I init pins like this :
LoRa.setPins(5, 14, 2)
On ESP32 mini there is no Pin14, I do not unterstand how to connect ?
There is a RST pin on this ESP32 mini board, but it does not work.
If I declare another pin instead of 14, and declare it in setPins, doesnt work also.
Always Lora.Begin fails.
Can someone help me, please
thanks
