On the Mikrotik gateway
I see only Join-Request in the Lora Traffic log
under the udp packet forwarder I see;
Valid RX Count: 1071
RX Forwarded: 1071
ACK Percentage: 99
Downlinks: 0
TX Count: 0
I conclude Join Request flows through gateway, ends under my devices in the Application on TTN - but devices are newer fully registered and therefore I newer start receiving data
Yes to that - prove GW/node combination works correctly 1st then look at ant improvements - 6dbi at the upper end of what I would ever consider - 'cause…well forum search helps! If you are only working with local nodes closer to isotropic pattern works best for allround coverage…
Lots of GW join requests but no join-accepts seen at the GW or in console? Suggests registration problem - have you applied the correct AppKeys as provided by Browan?
What RSSI/SNR levels are you actually seeing? GW & Devices set to same freq plan? RX2 on?? RX 1/2 delay set at ??
1st is App Eui (Join EUI) 2nd is Dev EUI…what is also critical is the AppKey - keep that obscured but double double check you have that right - it will be unique to each device, make sure you havent swapped between devices
Ah that wont help as you then need to programme that into the device! They come with a key pre-assigned - usually on a slip of paper! If you find it simply go in and edit and save changes…hopefully LNS will then recognise your device…
