Stuck in otaa join loop
Hello all,
I have a strega emitter node. The device is configured as required by the manufacturer. While trying to perform an OTAA Join. The device successfully Joined for the first time.
After a reset to update non-lorawan parameters using the SE/SV Reader tool, the device has since been stuck in a OTAA JOIN Loop.
The device console log is as shown in the Image below. This has been happening for sometime now.
JOIN LOOP
I have checked and counter checked the device credentials. They are set correctly.
I have tried deleting the device from the application and registering it again with no success. It is still stuck in the join loop.
Kindly help me out with the following:
  1. What is the cause of this
  2. Possible solutions/attempts at solution that may work.
Thank you in advance.
Your signal levels show you’re pretty close to the gateway, so presumably it’s yours.
What do you see in the gateway traffic page?
Thanks @cslorabox. I own the gateway(Lorank) and have it on my lab window. The gateway transmissions are as in the image below:
JOIN LOOP
No, we need to see the actual raw traffic on the gateway’s page.
You’ve just posted the device page’s view over again.
