I have RAK 5146 Lorawan Gateway, which is connected to Raspberry-pi[4B] using Pi-Hat2013. Until now, I have successfully sent the sensor data to the Things Network with the help of RAK 3172 Lora Module and RAK 5146 Lorawan Gateway. Also, I can save to data in influx DB with the help of Node-red MQTT protocol [Which is running in Raspberry-pi] and TTN MQTT as Broker. But this is achieved in case when data is received at TTN. I want to store the data locally in raspberry-pi before sending it to The Things Network, so when the internet is not available, I am sure that my data is not lost and also, I want to prepare the dashboard locally. So, is there any way, that the data packets which is received by Lorawan gateway, I can collect the data in influx DB and then send it to TTN.
Can anyone help me?
Thanks in advance!!
