Spectrum analyser on EU 868 MHz
I recently bought an RF explorer http://rfexplorer.com/ handheld spectrum analyser to get a better look at the normal EU LoRaWAN channel lineup and to measure the noise floor and potential interference during site surveys at gateway locations.
I’m very impressed, both with the handheld unit and with the PC software that can access the unit via USB. I’m also more and more impressed with the very low-cost Semtech technology.
This is a screenshot of the PC application after about 48 hours of running in my workshop with a number of devices and a couple of gateways outside. The lines are min and max-hold.
RFExplorer-01
The markers are at the centre frequencies of the channels. I have no idea what the intermittent peaks around 869 Mhz and the constant peak at 870 MHz are. The noise floor is sitting at about -108 dBm as expected.
This is a screenshot looking at the channel separation between channel 3 at 867.1 MHz and channel 4 at 867.3 MHz. I’m impressed to see that the channel separation at 867.2 MHz is about 30dB.
RFExplorer-02
So, a good cheap tool on a good cheap radio system… bodes well for 2020!
Great post (@cultsdotelecomatgmai) that’s really interesting.
I’m interested in the noise floor levels you observed. Are these typical of city environments and in fact does this vary with any significance from sparse to built-up areas?
Working with a noise level around -110dBm, does this mean the limit for a Lora signal be somewhere in the range of -120 to -130dBm?
A noise floor of around -105dBm to -110dBm is typical, and does not seem to vary much between cities and hilltops in the countryside. I have an RFExplorer too.
And yes, the observed sensitivity limit for a LoRa signal is the noise floor - the SNR for the spreading factor. So a max ‘Real World’ sensitivity of -125dBm to -130dBm.
Certainly when I have done hilltop to hilltop long range testing with known transmiiter powers and antennas (so you can calculate the signal level you receiving) the failure level is very close to noise floor minus the SNR for the spreading factor, and as much as 15-20dBm outside the datasheet sensitivity figures.
Thanks for the details. While I have measured noise levels in the VHF and UHF bands I’ve no feel for noise levels around 900MHz and no experience if there is an increase near built-up areas.
This confirms my experience and when using RF Predictive tools I work on the basis of -120dBm is the minimum signal strength for design purposes.
Hi @TonySmith, most of my work is in LoRaWAN on farms in Scotland (lots of hills) and I use an RX sensitivity of -120 dBm for SF11 and an RX sensitivity of -115 dBm for SF9 radio prediction. We use SF9 planning to create coverage maps for customers with a Service Level Agreement (SLA). Farmers are very accustomed to patchy mobile network coverage so we provide the predicted LoRaWAN coverage data to them as Google Earth KMZ files and they generally become very supportive.
We have processed the radio metadata from a very large number of LoRaWAN uplinks RX at gateways and very rarely see a reported gateway RSSI below -120 dBm.
As reported by @LoRaTracker, most noise floor measurements show -105 to -110 dBm - except in heavy industrial environments where it’s higher, often around -100 dBm and can be very intermittent as machinery starts/stops and can temporarily rise as high as -90 dBm, which reduces range very significantly.
That’s exactly what I see. Graphing the gateway received RSSI for quite a few nodes over several years data and they are strikingly similar. All flat bottomed at -120dBm, rarely see anything less than this.
My installations are on relatively flat ground, with a number of nodes at the extreme of coverage.
With an inexpensive instrument, I’d want to try to make sure I was actually measuring environmental noise and not the limits of the instrument or its own noise figure.
Also important to note that the actual units of environmental noise are dBm per Hertz - the amount of power that implies depends on what bandwidth you integrate over. Radio engineering usually assumes physics imposes an ultimate noise floor of - 174 dBm/Hz, if you integrate that over 125 KHz bandwidth that’s a factor of 10^5.1 so it becomes -174 + 51 or -123 dBm of noise power in a typical LoRa uplink channel. Before any comparison can be made, it’s important to be using the same units.
Of course the chirp coding then further narrows that mathematically, which is why we can receive with a negative SNR relative to the noise in the channel’s simplistic bandwidth.
Great post… @cultsdotelecomatgmai
@LoRaTracker
I was wondering if I could use spectrum analyzer to sense the LoRa signal at normal IND LoRaWAN channel…
I am actually a btech student trying solve the problem of detecting the usage of LoRa network in a given area (specifically IND channel)
I need a help about to proceed with the problem…
It will be really helpful if u guys can recommend some hardware and software tools towards the approach
Of course, thats all the RFExplorer is, a portable spectrum analyzer.
To get a view of whats going on nearby an el-cheapo SDR with Airspy software is usually enough.
However do appreciate that LoRa signals from long distances are being received below noise level, so a Spectrum Analyser might not see the longer distance signals.
@LoRaTracker Thanks for the reply
I want to do everything in a software without actual RFExplorer for time being fro testing u can say… Software in the sense simulator like MATLAB etc. to sense those long distance low SNR signal and extract info(features from it)
How should i proceed with that??
Not easy to see things below the noise floor.
Gateway. :smiley:
No idea.
I cannot understand what you are trying to do, for instance, can you explain what this means;
“for time being fro testing u can say” ?
“Software in the sense simulator like MATLAB etc” ?
Is this a project you have been set as part of your studies? If so we are not here to play the part of realtime/human ChatGPT and solve for you :wink:
It’s pretty much a solved problem. Buy a gateway, turn it on and look at the gateway logs - it will show you everything that it hears that looks like LoRaWAN. If you want anything LoRa, buy a radio and write some code …
You appear to be contradicting yourself!
And RFExplorer won’t know if it’s LoRa or not, just know that there was a signal.
This conversation will have a very short lifespan if it’s not kept on point - forum policy is no homework - specific focused questions are OK but not a request for a general methodology - that’s what research is for.
