Hi everyone.
I have problem about sometime disconnect between esp32 and gateway by use LMIC.h. Now, i cannot solve the problem. can we recommend me or explain this problem what cause? and how to solve?
I need to explain solution: Esp32 already join lora OTAA with gateway by used LMIC.h. Sometime, the node didn’t uplink then i cannot send downlink from MQTT to node. but sometime, the node already join with gateway.
Then my problem: Node didn’t join lora with gateway real time.
Firmware:
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <esp_task_wdt.h>
//3 seconds WDT
#define WDT_TIMEOUT 900
// Relay
int value[3] = {};
char tmp[2];
int arr_relaypin = {0, 13, 25, 26, 33};//k1,k3,k2,k4
int arr_size = 4;
// LoRaWan
// f6 f4 f5 6a 29 67 bc 65
static const u1_t PROGMEM APPEUI[8]={ 0x65, 0xbc, 0x67, 0x29, 0x6a, 0xf5, 0xf4, 0xf6 };
static const u1_t PROGMEM DEVEUI[8]={ 0x65, 0xbc, 0x67, 0x29, 0x6a, 0xf5, 0xf4, 0xf6 };
// 6c c7 47 66 52 98 e3 92 4e c1 53 27 1e 19 af ca
static const u1_t PROGMEM APPKEY[16] = { 0x6c, 0xc7, 0x47, 0x66, 0x52, 0x98, 0xe3, 0x92, 0x4e, 0xc1, 0x53, 0x27, 0x1e, 0x19, 0xaf, 0xca };
void os_getDevKey (u1_t* buf) { memcpy_P(buf, APPKEY, 16);}
static uint8_t mydata = “00”;
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 10; // หน่วยเป็นวินาที
// Pin mapping
.nss = 18,
.rxtx = LMIC_UNUSED_PIN,
.rst = 14,
.dio = {2, 4, LMIC_UNUSED_PIN},
void printHex2(unsigned v) {
v &= 0xff;
if (v < 16)
Serial.print(‘0’);
Serial.print(v, HEX);
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch(ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F(“EV_SCAN_TIMEOUT”));
break;
case EV_BEACON_FOUND:
Serial.println(F(“EV_BEACON_FOUND”));
break;
case EV_BEACON_MISSED:
Serial.println(F(“EV_BEACON_MISSED”));
break;
case EV_BEACON_TRACKED:
Serial.println(F(“EV_BEACON_TRACKED”));
break;
case EV_JOINING:
Serial.println(F(“EV_JOINING”));
break;
case EV_JOINED:
Serial.println(F(“EV_JOINED”));
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
Serial.print("netid: ");
Serial.println(netid, DEC);
Serial.print(“devaddr: “);
Serial.println(devaddr, HEX);
Serial.print(“AppSKey: “);
for (size_t i=0; i<sizeof(artKey); ++i) {
if (i != 0)
Serial.print(”-”);
printHex2(artKey[i]);
Serial.println(””);
Serial.print(“NwkSKey: “);
for (size_t i=0; i<sizeof(nwkKey); ++i) {
if (i != 0)
Serial.print(”-”);
printHex2(nwkKey[i]);
Serial.println();
LMIC_setLinkCheckMode(0);
break;
case EV_JOIN_FAILED:
break;
case EV_REJOIN_FAILED:
break;
case EV_TXCOMPLETE:
if (LMIC.dataLen) {
Serial.print(F("Data Received: "));
String dpayload = "";
char temp[3];
for(uint8_t i=0;i<LMIC.dataLen;i++)
// Serial.println(i);
Serial.print(LMIC.frame[LMIC.dataBeg + i], HEX);
// sprintf(temp, "%02x", LMIC.frame[LMIC.dataBeg + i]);
sprintf(temp ,"%x", LMIC.frame[LMIC.dataBeg + i]);
dpayload = String(dpayload) + String(temp);
Serial.println(dpayload);
Serial.println();
if(dpayload != ""){
pinMode(arr_relaypin[1], OUTPUT);
pinMode(arr_relaypin[2], OUTPUT);
pinMode(arr_relaypin[3], OUTPUT);
pinMode(arr_relaypin[4], OUTPUT);
dpayload = dpayload.substring(0, 12);
if (dpayload.length() == 12) {
String cmd_status = String(dpayload.substring(1, 2)) + String(dpayload.substring(3, 4));
String cmd_pin = dpayload.substring(5, 6) + dpayload.substring(7, 8);
String cmd_time = dpayload.substring(9, 10) + dpayload.substring(11, 12);
int pin = cmd_pin.toInt();
long timedelay = cmd_time.toInt() * 1000* 60 ;
if(cmd_status =="01"){
for(int i = 1; i <= arr_size; i++){
Serial.print(String(i) + ". Pin "+String(arr_relaypin[i])+ " Status: ");
Serial.println(digitalRead(arr_relaypin[i]));
sprintf(tmp,"%02d",digitalRead(arr_relaypin[i]));
}else if(cmd_status =="02"){
if(cmd_pin=="99"){
Serial.println("Payload: " + dpayload);
Serial.println("Relay No: BOTH");
Serial.println("Turn On...");
for(int i = 1; i<= arr_size; i++){
digitalWrite(arr_relaypin[i], HIGH);
Serial.print("Delay: ");
Serial.print(timedelay);
Serial.println(" ms");
delay( timedelay );
digitalWrite(arr_relaypin[i], LOW);
Serial.println("Turn Off...");
}else{
Serial.print("Relay No: ");
Serial.println(pin);
Serial.print("Pin: ");
Serial.println(arr_relaypin[pin]);
digitalWrite(arr_relaypin[pin], HIGH);
delay( timedelay );
digitalWrite(arr_relaypin[pin], LOW);
}else{
Serial.println("!! Package Lost : Payload Error !!");
Serial.print("Payload: ");
Serial.println();
esp_task_wdt_reset();
break;
case EV_LOST_TSYNC:
break;
case EV_RESET:
break;
case EV_RXCOMPLETE:
// data received in ping slot
break;
case EV_LINK_DEAD:
break;
case EV_LINK_ALIVE:
break;
case EV_TXSTART:
break;
case EV_TXCANCELED:
Serial.println(F("EV_TXCANCELED"));
break;
case EV_RXSTART:
/* do not print anything -- it wrecks timing */
break;
case EV_JOIN_TXCOMPLETE:
Serial.println(F("EV_JOIN_TXCOMPLETE: no JoinAccept"));
break;
default:
break;
void do_send(osjob_t* j){
Serial.println(F(“OP_TXRXPEND, not sending”));
} else {
LMIC_setTxData2(22, mydata, sizeof(mydata)-1, 0);
Serial.println(F(“Packet queued”));
void setup() {
Serial.begin(115200);
Serial.println(F(“Starting”));
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
delay(1000);
#endif
Serial.println("Configuring WDT...");
esp_task_wdt_init(WDT_TIMEOUT, true); //enable panic so ESP32 restarts
esp_task_wdt_add(NULL); //add current thread to WDT watch
// LMIC init
os_init();
LMIC_reset();
LMIC_setDrTxpow(DR_SF9,14);
LMIC_setClockError(MAX_CLOCK_ERROR * 10 / 100);
// Start job
do_send(&sendjob);
int i = 0;
int last = millis();
void loop() {
os_runloop_once();
