[solved]ttn.showStatus() returns empty values
Hi everybody,
I have a little problem. I followed this tutorial: https://www.thethingsnetwork.org/docs/devices/uno/quick-start.html to get the device address of my Feather32u4. But the function ttn.showStatus(); returns only empty values.
-- STATUS
EUI:
Battery:
AppEUI:
DevEUI:
Does anybody have an idea what the problem could be? I would be very thankful.
Best wishes
Pasci
yes, you are using a code example for the TNN uno. but you seems to use a Feather32U4…
Ahh okay, yes this is true. I’m using a Feather32u. Do you know which changes I need to make or where I can find informations?
use search ?
I have the same problem but with The Things Uno. I’m using stock DeviceInfo code from examples ( changed frequPlan)
what OS do you use
what arduino IDE version
are the TTN libs installed
did you select arduino leonardo
did you then select a port (different then 1)
could you upload the sketch without a problem
ok now reset uno (press button on board)
see if port changed and select that port
open serial monitor
OS: Windows 7
IDE: Arduino 1.8.8
TNN libs installed: Yes
Arduino Leonardo selected: Yes
Current port COM17
The reset button trick worked. Port didn’t change but next time I tried to upload I got a notice that I should press the reset button again “during an upload” … that did it.
