Hello
I can see the data in TTN Console Gateway.
There is no data in ‘Applications>…>Data’ or ‘Applications>…>Devices>…>Data’.
Device status is ‘never seen’.
In ATIM devices, only EUI (DevEUI and AppEUI) are read in little endian.
DevEUI and AppEUI bytes must me reordered in big endian before registering device on TTN
I attach screenshots from Tera Term with connection to ATIM usb dongle and from the console ‘Gateway Traffic’ and ‘Application Data’.
I attach screenshots of running Microchip Lora Mote on the same Gateway.
Thank you for your response.
Yes, thank you, I know about ordered of the keys. I used the instructions to which the link was given in the first post.
I attach screenshots from TTN console.
If OTAA was enabled, you should see the JOIN request on your Gateway console before the first uplink.
Your ATIM device seems to use ABP instead of OTAA.
Check the content of ATO83 register.
The lower bit of ATO83 register must be set to 1 to enable OTAA.
