I’m having troubles configuring a LT-33222 from Dragino using AT commands. On every command I get the response “AT_ERROR”.
I entered the password and the device responded with “Correct password”.
AT commands without a “+” in it like “ATZ” work fine. Commands like “AT+NJS=?” fail.
So it might be a problem with the encoding/terminal type.
If somebody has a working connection, please share your settings here.
I’m using a TTL USB Serial converter attached to a Mac, 9600/8/N/1
All good with other devices, attached an Arduino to capture serial output -> data is fine.
It have a second device, going for a try with this one too.
