[solved] LoRa32u4 II joins only sometimes
Hi everyone,
I just bought a LoRa32u4 from BSFrance but I can’t get it working properly. The activation via OTAA seems to work but the board rarely sends the payload. Only once of 100 times the board really joins ttn.
I added the line “LMIC_setClockError(MAX_CLOCK_ERROR * 1 / 100);” in the setup and changed in hal.cpp:
static const SPISettings settings(8E6, MSBFIRST, SPI_MODE0);
As it connects a very few times, the keys are alright. The messages in the serial monitor are:
Starting
Packet queued
End of setup
1438534: EV_JOINING
after EV_JOINING
FAILURE
C:\Users\Peter\Documents\Arduino\libraries\arduino-lmic-master\src\lmic\radio.c:660
The code I’m using is:
 * Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
 * Permission is hereby granted, free of charge, to anyone
 * obtaining a copy of this document and accompanying files,
 * to do whatever they want with them without any restriction,
 * including, but not limited to, copying, modification and redistribution.
 * NO WARRANTY OF ANY KIND IS PROVIDED.
 * This example sends a valid LoRaWAN packet with payload "Hello,
 * world!", using frequency and encryption settings matching those of
 * the The Things Network.
 * This uses OTAA (Over-the-air activation), where where a DevEUI and
 * application key is configured, which are used in an over-the-air
 * activation procedure where a DevAddr and session keys are
 * assigned/generated for use with all further communication.
 * Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
 * g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
 * violated by this sketch when left running for longer)!
 * To use this sketch, first register your application and device with
 * the things network, to set or generate an AppEUI, DevEUI and AppKey.
 * Multiple devices can use the same AppEUI, but each device has its own
 * DevEUI and AppKey.
 * Do not forget to define the radio type correctly in config.h.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
// 0x70.
static const u1_t PROGMEM APPEUI[8]={ xxx };
static const u1_t PROGMEM DEVEUI[8]={ xxx };
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] = { xxx };
void os_getDevKey (u1_t* buf) {  memcpy_P(buf, APPKEY, 16);}
static uint8_t mydata[] = "O";
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 180;
// Pin mapping
    .nss = 8,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 4,
    .dio = {7, 6, LMIC_UNUSED_PIN}, // Specify pin numbers for DIO0, 1, 2
    // connected to D7, D6, -
void onEvent (ev_t ev) {
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            break;
        case EV_BEACON_FOUND:
            break;
        case EV_BEACON_MISSED:
            break;
        case EV_BEACON_TRACKED:
            break;
        case EV_JOINING:
            Serial.println(F("after EV_JOINING"));
            break;
        case EV_JOINED:
            // during join, but not supported by TTN at this time).
            LMIC_setLinkCheckMode(0);
            break;
        case EV_RFU1:
            Serial.println(F("EV_RFU1"));
            break;
        case EV_JOIN_FAILED:
            break;
        case EV_REJOIN_FAILED:
            break;
            break;
        case EV_TXCOMPLETE:
            if (LMIC.dataLen) {
              Serial.println(LMIC.dataLen);
            // Schedule next transmission
            break;
        case EV_LOST_TSYNC:
            break;
        case EV_RESET:
            break;
        case EV_RXCOMPLETE:
            // data received in ping slot
            break;
        case EV_LINK_DEAD:
            break;
        case EV_LINK_ALIVE:
            break;
         default:
            break;
void do_send(osjob_t* j){
    } else {
void setup() {
    Serial.begin(9600);
    while (!Serial){
      delay(100);
    #ifdef VCC_ENABLE
    // For Pinoccio Scout boards
    pinMode(VCC_ENABLE, OUTPUT);
    delay(1000);
    #endif
    // LMIC init
    os_init();
    LMIC_reset();
    // Let LMIC compensate for +/- 1% clock error
    do_send(&sendjob);
    Serial.println(F("End of setup"));
void loop() {
    os_runloop_once();
If anyone has an idea how to get it working properly, please let me know.
Best regards,
Peter
There are a number of variations off this board. Are you sure you are using the right pin mappings?
All the information I have is the datasheet form BSFrance:
But it’s true, that the board in the given pinout diagram looks slightly different than mine. On the very bottom I don’t have the two wholes. In the pinout diagramm is written:
RST - D4
NSS - D8
The DIO1 is connected to Pin 6.
As the payload is sent sometimes I guess, the mapping is right. Assuming, that without the right pin mapping the payload would never be sent.
But I have an idea, what could be wrong. I ordered a 868 MHz board but on the bill is written “915M”. I’ll contact the supplier. Is there any way to find out the frequency of the bord?
Hi all,
I solved it! Pin DIO1 is not the very last Pin as mentioned in the datasheet but it is the last but one. As I resoldered the DIO1 jumper in the back because I thought it wasn’t working i’ve seen the conductive path not going to the last pin.
Thank you for your help. I’ll write BSFrance to update their datasheet.
