Yes - set to Europe 868MHz
Yes - clksrc set to 1
“clksrc”: 1,
“chan_multiSF_7”: {
“enable”: true,
“radio”: 0,
“if”: 400000,
“desc”: “Lora MAC, 125kHz, all SF, 867.9 MHz”
This is a part of the Resin.io log -
31.07.17 22:49:09 (+0000) [TTN Gateway]: Resetting concentrator on pin 22
31.07.17 22:49:10 (+0000) *** Multi Protocol Packet Forwarder for Lora Gateway ***
31.07.17 22:49:10 (+0000) Version: 3.0.0
31.07.17 22:49:10 (+0000) *** Lora concentrator HAL library version info ***
31.07.17 22:49:10 (+0000) Version: 5.0.1; Options: native;
31.07.17 22:49:10 (+0000) INFO: Little endian host
31.07.17 22:49:10 (+0000) INFO: found global configuration file global_conf.json, parsing it
31.07.17 22:49:10 (+0000) INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
31.07.17 22:49:10 (+0000) INFO: lorawan_public 1, clksrc 1
31.07.17 22:49:10 (+0000) lgw_board_setconf:437: Note: board configuration; lorawan_public:1, clksrc:1
31.07.17 22:49:10 (+0000) INFO: no configuration for LBT
31.07.17 22:49:10 (+0000) INFO: antenna_gain 0 dBi
31.07.17 22:49:10 (+0000) INFO: Configuring TX LUT with 16 indexes
31.07.17 22:49:10 (+0000) INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1
31.07.17 22:49:10 (+0000) lgw_rxrf_setconf:486: WARNING: NOT A VALID TX NOTCH FILTER FREQUENCY [126000…250000]Hz
31.07.17 22:49:10 (+0000) lgw_rxrf_setconf:498: Note: rf_chain 0 configuration; en:1 freq:867500000 rssi_offset:-166.000000 radio_type:2 tx_enable:1 tx_notch_freq:0
31.07.17 22:49:10 (+0000) INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0
31.07.17 22:49:10 (+0000) lgw_rxrf_setconf:498: Note: rf_chain 1 configuration; en:1 freq:868500000 rssi_offset:-166.000000 radio_type:2 tx_enable:0 tx_notch_freq:0
31.07.17 22:49:10 (+0000) INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:617: Note: LoRa ‘multi’ if_chain 0 configuration; en:1 freq:-400000 SF_mask:0x7e
31.07.17 22:49:10 (+0000) INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:617: Note: LoRa ‘multi’ if_chain 1 configuration; en:1 freq:-200000 SF_mask:0x7e
31.07.17 22:49:10 (+0000) INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:617: Note: LoRa ‘multi’ if_chain 2 configuration; en:1 freq:0 SF_mask:0x7e
31.07.17 22:49:10 (+0000) INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:617: Note: LoRa ‘multi’ if_chain 3 configuration; en:1 freq:-400000 SF_mask:0x7e
31.07.17 22:49:10 (+0000) INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:617: Note: LoRa ‘multi’ if_chain 4 configuration; en:1 freq:-200000 SF_mask:0x7e
31.07.17 22:49:10 (+0000) INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:617: Note: LoRa ‘multi’ if_chain 5 configuration; en:1 freq:0 SF_mask:0x7e
31.07.17 22:49:10 (+0000) INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:617: Note: LoRa ‘multi’ if_chain 6 configuration; en:1 freq:200000 SF_mask:0x7e
31.07.17 22:49:10 (+0000) INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:617: Note: LoRa ‘multi’ if_chain 7 configuration; en:1 freq:400000 SF_mask:0x7e
31.07.17 22:49:10 (+0000) INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:591: Note: LoRa ‘std’ if_chain 8 configuration; en:1 freq:-200000 bw:2 dr:2
31.07.17 22:49:10 (+0000) INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
31.07.17 22:49:10 (+0000) lgw_rxif_setconf:647: Note: FSK if_chain 9 configuration; en:1 freq:300000 bw:3 dr:50000 (50000 real dr) sync:0xC194C1
31.07.17 22:49:10 (+0000) INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
31.07.17 22:49:10 (+0000) INFO: gateway MAC address is configured to B827EBFFFE8D952B
31.07.17 22:49:10 (+0000) INFO: Found 1 servers in array.
31.07.17 22:49:10 (+0000) INFO: Server 0 configured to “bridge.eu.thethings.network”
I found this warning in the log -
Maybe this is causing the problem?
