[Solved] IC880A Status not connected
pic5
pic6
pi@ttn-gateway:~ $ sudo tail -f /var/log/syslog
Jun 4 12:32:08 ttn-gateway ttn-gateway[3789]: INFO: Description configured to "IC880A-SPI + RPI3 B+"
Jun 4 12:32:08 ttn-gateway ttn-gateway[3789]: INFO: Successfully contacted server router.eu.thethings.network
Jun 4 12:32:08 ttn-gateway ttn-gateway[3789]: INFO: [main] Starting the concentrator
Jun 4 12:32:08 ttn-gateway ttn-gateway[3789]: ERROR: [main] failed to start the concentrator
Jun 4 12:32:08 ttn-gateway systemd[1]: ttn-gateway.service: Unit entered failed state.
Jun 4 12:32:08 ttn-gateway systemd[1]: ttn-gateway.service: Failed with result ‘exit-code’.
Jun 4 12:32:13 ttn-gateway systemd[1]: ttn-gateway.service: Service hold-off time over, scheduling restart.
Jun 4 12:32:13 ttn-gateway systemd[1]: Stopped The Things Network Gateway.
Jun 4 12:32:13 ttn-gateway systemd[1]: Started The Things Network Gateway.
Jun 4 12:32:13 ttn-gateway ttn-gateway[3830]: /opt/ttn-gateway/gateway-remote-config /opt/ttn-gateway/bin
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: Already up-to-date.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: HEAD is now at dc922da Merge pull request #1325 from luctse/master
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: /opt/ttn-gateway/bin
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: [TTN Gateway]: Use Gateway EUI B827EBFFFECF827B based on eth0
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: *** Poly Packet Forwarder for Lora Gateway ***
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: Version: 2.1.0
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: *** Lora concentrator HAL library version info ***
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: Version: 3.1.0; Options: native;
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Little endian host
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: found global configuration file global_conf.json, parsing it
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: lorawan_public 1, clksrc 1
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Configuring TX LUT with 16 indexes
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: gateway MAC address is configured to AA555A0000000000
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Found 2 servers in array.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Server 0 configured to "127.0.0.1", with port up "1680" and port down "1681"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Server 1 configured to "iot.semtech.com", with port up "1680" and port down "1680"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Found 5 system calls in array.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 0: "df -m"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 1: "free -h"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 2: "uptime"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 3: "who -a"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 4: "uname -a"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: monitor hostname or IP address is configured to "127.0.0.1"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: monitor port is configured to "2008"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: ghost hostname or IP address is configured to "127.0.0.1"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: ghost port is configured to "1918"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: downstream keep-alive interval is configured to 10 seconds
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: statistics display interval is configured to 30 seconds
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: upstream PUSH_DATA time-out is configured to 100 ms
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: packets received with a valid CRC will be forwarded
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: packets received with a CRC error will NOT be forwarded
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: packets received with no CRC will NOT be forwarded
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: GPS serial port path is configured to "/dev/ttyAMA0"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: SSH path is configured to "/usr/bin/ssh"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: SSH port is configured to 22
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: HTTP port is configured to 80
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: NGROK path is configured to "/usr/bin/ngrok"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference latitude is configured to 10.000000 deg
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference longitude is configured to 20.000000 deg
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference altitude is configured to -1 meters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: GPS is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Using fake GPS coordinates instead of real.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: antenna_gain 0 dBi
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Upstream data is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Downstream data is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Ghoststream data is disabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Radiostream data is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Statusstream data is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Beacon is disabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Monitor is disabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Platform configured to "IMST + Rpi"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Contact email configured to *
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Description configured to "Update me"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: found local configuration file local_conf.json, parsing it
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: redefined parameters will overwrite global parameters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: local_conf.json does not contain a JSON object named SX1301_conf
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: gateway MAC address is configured to B827EBFFFECF827B
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Found 1 servers in array.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Server 0 configured to "router.eu.thethings.network", with port up "1700" and port down "1700"
Jun 4 12:32:15 ttn-gateway systemd[1]: ttn-gateway.service: Main process exited, code=exited, status=1/FAILURE
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference latitude is configured to 36.779545 deg
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference longitude is configured to 10.277054 deg
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference altitude is configured to 1 meters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Description configured to "IC880A-SPI + RPI3 B+"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Successfully contacted server router.eu.thethings.network
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: [main] Starting the concentrator
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: ERROR: [main] failed to start the concentrator
Jun 4 12:32:15 ttn-gateway systemd[1]: ttn-gateway.service: Unit entered failed state.
Jun 4 12:32:15 ttn-gateway systemd[1]: ttn-gateway.service: Failed with result ‘exit-code’.
