Hello guys I have RPi 3 + ic880a gateway. On console it shows it is not connected. I did all the steps and my EUI code is registered in the Gateway Remote Config repository what’s the problem guys can you give me some command line to verify the connexion status and thank you for your help
is your SPI interface enabled ?
sudo raspi-config
Yes i Enabled
the device has a working internet connection and you’ve runned the install script
I didn’t understand what’s the install script ? but the device is connected to working internet
what steps did you take and from which tutorial ?
Those steps from GitHub Sir :
this step is important
- Clone the installer and start the installation
$ git clone -b spi https://github.com/ttn-zh/ic880a-gateway.git ~/ic880a-gateway
$ cd ~/ic880a-gateway
$ sudo ./install.sh spi
Yes i did it and i did all those steps but the same problem
TTN doesn’t know your gateway ID at this moment , something in the installation steps went wrong and your GW is not forwarding data .
( WARNING : never power up without the antenna! )
No i didn’t connect any Node Because the status of the gateway ( not connected )
Hi @Skmark, I use the following CLI/bash command on the RPI to check that the packet forwarder software is running correctly:
$ sudo systemctl status ttn-gateway.service
You should get output that looks something like:
? ttn-gateway.service - The Things Network Gateway
Loaded: loaded (/lib/systemd/system/ttn-gateway.service; enabled)
Active: active (running) since Fri 2017-06-09 13:14:22 UTC; 2h 31min ago
Main PID: 433 (start.sh)
CGroup: /system.slice/ttn-gateway.service
±433 /bin/bash /opt/ttn-gateway/bin/start.sh
±815 ./poly_pkt_fwd
If it is not running then you should be able to try to start the forwarder with a command like:
$ sudo systemctl start ttn-gateway.service
If these do not work then there is something wrong with the hardware or software and you can try to manually start the forwarder and look at the console output.
see if anything is received/forwarded
sudo tcpdump -AUq port 1700
sudo tcpdump -AUq port 1700 -v
sudo tail -f /var/log/syslog
pi@ttn-gateway:~ $ sudo tail -f /var/log/syslog
Jun 4 12:32:08 ttn-gateway ttn-gateway[3789]: INFO: Description configured to "IC880A-SPI + RPI3 B+"
Jun 4 12:32:08 ttn-gateway ttn-gateway[3789]: INFO: Successfully contacted server router.eu.thethings.network
Jun 4 12:32:08 ttn-gateway ttn-gateway[3789]: INFO: [main] Starting the concentrator
Jun 4 12:32:08 ttn-gateway ttn-gateway[3789]: ERROR: [main] failed to start the concentrator
Jun 4 12:32:08 ttn-gateway systemd[1]: ttn-gateway.service: Unit entered failed state.
Jun 4 12:32:08 ttn-gateway systemd[1]: ttn-gateway.service: Failed with result ‘exit-code’.
Jun 4 12:32:13 ttn-gateway systemd[1]: ttn-gateway.service: Service hold-off time over, scheduling restart.
Jun 4 12:32:13 ttn-gateway systemd[1]: Stopped The Things Network Gateway.
Jun 4 12:32:13 ttn-gateway systemd[1]: Started The Things Network Gateway.
Jun 4 12:32:13 ttn-gateway ttn-gateway[3830]: /opt/ttn-gateway/gateway-remote-config /opt/ttn-gateway/bin
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: Already up-to-date.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: HEAD is now at dc922da Merge pull request #1325 from luctse/master
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: /opt/ttn-gateway/bin
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: [TTN Gateway]: Use Gateway EUI B827EBFFFECF827B based on eth0
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: *** Poly Packet Forwarder for Lora Gateway ***
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: Version: 2.1.0
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: *** Lora concentrator HAL library version info ***
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: Version: 3.1.0; Options: native;
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Little endian host
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: found global configuration file global_conf.json, parsing it
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: global_conf.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: lorawan_public 1, clksrc 1
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Configuring TX LUT with 16 indexes
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: gateway MAC address is configured to AA555A0000000000
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Found 2 servers in array.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Server 0 configured to "127.0.0.1", with port up "1680" and port down "1681"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Server 1 configured to "iot.semtech.com", with port up "1680" and port down "1680"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Found 5 system calls in array.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 0: "df -m"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 1: "free -h"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 2: "uptime"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 3: "who -a"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: System command 4: "uname -a"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: monitor hostname or IP address is configured to "127.0.0.1"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: monitor port is configured to "2008"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: ghost hostname or IP address is configured to "127.0.0.1"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: ghost port is configured to "1918"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: downstream keep-alive interval is configured to 10 seconds
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: statistics display interval is configured to 30 seconds
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: upstream PUSH_DATA time-out is configured to 100 ms
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: packets received with a valid CRC will be forwarded
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: packets received with a CRC error will NOT be forwarded
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: packets received with no CRC will NOT be forwarded
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: GPS serial port path is configured to "/dev/ttyAMA0"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: SSH path is configured to "/usr/bin/ssh"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: SSH port is configured to 22
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: HTTP port is configured to 80
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: NGROK path is configured to "/usr/bin/ngrok"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference latitude is configured to 10.000000 deg
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference longitude is configured to 20.000000 deg
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference altitude is configured to -1 meters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: GPS is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Using fake GPS coordinates instead of real.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: antenna_gain 0 dBi
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Upstream data is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Downstream data is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Ghoststream data is disabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Radiostream data is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Statusstream data is enabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Beacon is disabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Monitor is disabled
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Platform configured to "IMST + Rpi"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Contact email configured to *
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Description configured to "Update me"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: found local configuration file local_conf.json, parsing it
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: redefined parameters will overwrite global parameters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: local_conf.json does not contain a JSON object named SX1301_conf
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: gateway MAC address is configured to B827EBFFFECF827B
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Found 1 servers in array.
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Server 0 configured to "router.eu.thethings.network", with port up "1700" and port down "1700"
Jun 4 12:32:15 ttn-gateway systemd[1]: ttn-gateway.service: Main process exited, code=exited, status=1/FAILURE
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference latitude is configured to 36.779545 deg
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference longitude is configured to 10.277054 deg
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Reference altitude is configured to 1 meters
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Description configured to "IC880A-SPI + RPI3 B+"
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: Successfully contacted server router.eu.thethings.network
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: INFO: [main] Starting the concentrator
Jun 4 12:32:15 ttn-gateway ttn-gateway[3830]: ERROR: [main] failed to start the concentrator
Jun 4 12:32:15 ttn-gateway systemd[1]: ttn-gateway.service: Unit entered failed state.
Jun 4 12:32:15 ttn-gateway systemd[1]: ttn-gateway.service: Failed with result ‘exit-code’.
ok… what you can see it that it takes a few restarts to start the packetforwarder… that’s ’ normal
but what wrong is the … hmmm no
okay Sir see you
Is this the file ?
I’m still here… difficult to leave, many things going on here.
anyway, yes that’s the file but that one is ok.
this command you must leave running for a while of course… see if any node data can be captured… sudo tcpdump -AUq port 1700 -v
