Please someone can tell me if you know a Smoke sensor with LoraWan and ttn integration…?
Many thanks…!!!
Many thanks…!!!
Yes I can.
But you can use google, the Lora Alliance database or other sources. Or search the forum, this isn’t the first time smoke detectors come up.
I build a AQI sensor connected to the TTN, theoretically it can better detect smoke compare with the Infrared photodetector. You can find the schematic and the Firmware here, if you want to DIY:
