Sleep mode + pin change interrupt + Trigger
My Project: I want my Arduino sleep, if I trigger a button, my Arduino should wake up, send a massage to TTN and then go back to sleep.
Sending Data works fantastic, without any Problems, i also found sleep mode topics and implemented them and they also work. I don’t know if this is important for my Problem but I use Arduino Pro MINI and OTAA.
Idea: I want to use another Pin (in my case A5) as interrupt and not the standard one ( I think it was INT0 and INT1)
Solution: Pin change interrupt (or if you have a better solution)
Problem: I have Coding Problems
Implementation:
I) Button Code (pin change interrupt)
  1. Turn on Pin Change Interrupts
PCICR = B00100000; // enable PCIE1 group
  1. Chose which pins to interrupt on
PCMSK1 = B00000001; //enable PCINT13 (A5)
  1. Write an ISR for those pins
ISR(PCINT1_vect)
II) Sleepmode Code
Lowpower.h
I am not a professional coder, but i tried to combine the low power library with the pin change interrup settings. Well in the end it doesnt work. Have somebody experience with sleepmode + pin change interrup? i appreciate your help.
// **** INCLUDES *****
#include "LowPower.h"
// Use pin 2 as wake up pin
const int wakeUpPin = A5;
void wakeUp()
    // Just a handler for the pin interrupt.
void setup()
    // Configure wake up pin as input.
    // This will consumes few uA of current.
   pinMode(wakeUpPin, INPUT_PULLUP); // internal Resistor
   PCIFR = B00000000; // clear all interrupt flags
void loop()
    // Allow wake up pin to trigger interrupt on low.
    attachInterrupt(0, wakeUp, LOW);
    // Enter power down state with ADC and BOD module disabled.
    // Wake up when wake up pin is low.
    LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
    // Disable external pin interrupt on wake up pin.
    detachInterrupt(0);
    // Do something here
    // Example: Read sensor, data logging, data transmission.
   ISR(PCINT1_vect) {
   state = !state;
Pins A6,A7 on an ATmega328P (Pro Mini) are analog only, they are not digital pins.
Sry, its A5, in the code its corect
This lot, from your code, does not look correct;
the low power library that i found used pin 2 as interupt. I cant use pin 2 so i tried pin change interrupt feature. The question is, whether my A5 is the new interrupter instead of Pin 2 or is it the case that if i trigger A5, it will trigger Pin2 which will trigger my sleep mode feature? I will post the code later, cause i want to try something out.
If you want to use pins other than D2 and D3, you can use the EnableInterrupt library.
Awesome, this library makes it a lot easier. That`s maybe embarrassing, so pls dont kill me right away :sweat_smile:. I installed the library and added this code. After that i changed the values and it gives me back on error if i try to compile: "expected primary-expression before ‘A5’ " . My goal is to make a trigger, which will tell me whether the door is open or not. i posted here also my code. I appreciate your help.
 enableInterrupt(uint8_t pinNumber, void (*userFunction)(void), uint8_t mode);
 * Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
 * Copyright (c) 2018 Terry Moore, MCCI
 * Permission is hereby granted, free of charge, to anyone
 * obtaining a copy of this document and accompanying files,
 * to do whatever they want with them without any restriction,
 * including, but not limited to, copying, modification and redistribution.
 * NO WARRANTY OF ANY KIND IS PROVIDED.
 * This example sends a valid LoRaWAN packet with payload "Hello,
 * world!", using frequency and encryption settings matching those of
 * the The Things Network.
 * This uses OTAA (Over-the-air activation), where where a DevEUI and
 * application key is configured, which are used in an over-the-air
 * activation procedure where a DevAddr and session keys are
 * assigned/generated for use with all further communication.
 * Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
 * g1, 0.1% in g2), but not the TTN fair usage policy (which is probably
 * violated by this sketch when left running for longer)!
 * To use this sketch, first register your application and device with
 * the things network, to set or generate an AppEUI, DevEUI and AppKey.
 * Multiple devices can use the same AppEUI, but each device has its own
 * DevEUI and AppKey.
 * Do not forget to define the radio type correctly in
 * arduino-lmic/project_config/lmic_project_config.h or from your BOARDS.txt.
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <EnableInterrupt.h>
// 0x70.
static const u1_t PROGMEM APPEUI[8] = { };
void os_getArtEui (u1_t* buf) {
  memcpy_P(buf, APPEUI, 8);
static const u1_t PROGMEM DEVEUI[8] = { };
void os_getDevEui (u1_t* buf) {
  memcpy_P(buf, DEVEUI, 8);
// practice, a key taken from ttnctl can be copied as-is.
// The key shown here is the semtech default key.
static const u1_t PROGMEM APPKEY[16] = {};
void os_getDevKey (u1_t* buf) {
  memcpy_P(buf, APPKEY, 16);
static osjob_t sendjob;
unsigned TX_INTERVAL = 20;
  .nss = 10,
  .rxtx = LMIC_UNUSED_PIN,
  .rst = LMIC_UNUSED_PIN,
  .dio = {2, 7, 8},              // (DIO0,DIO1,DIO2)
int ledPin = 13;//LED
void onEvent (ev_t ev) {
  Serial.println("TX_Intervall lautet:");
  Serial.println(TX_INTERVAL);
    Serial.print((unsigned long)(os_getTime()/ OSTICKS_PER_SEC));
    Serial.print(": ");
    switch(ev) {
        case EV_SCAN_TIMEOUT:
            break;
        case EV_BEACON_FOUND:
            break;
        case EV_BEACON_MISSED:
            break;
        case EV_BEACON_TRACKED:
            break;
        case EV_JOINING:
            Serial.println(F("EV_JOINING")); //The node has started joining the network
            break;
        case EV_JOINED:                     //The node has successfully joined the network and is now ready for dara exchange
              u4_t netid = 0;
              devaddr_t devaddr = 0;
              u1_t nwkKey[16];
              u1_t artKey[16];
              Serial.print("netid: ");
              Serial.println(netid, DEC);
              Serial.print("devaddr: ");
              Serial.println(devaddr, HEX);
              Serial.print("artKey: ");
              for (int i=0; i<sizeof(artKey); ++i) {
                Serial.print(artKey[i], HEX);
              Serial.println("");
              Serial.print("nwkKey: ");
              for (int i=0; i<sizeof(nwkKey); ++i) {
                Serial.print(nwkKey[i], HEX);
              Serial.println("");
            LMIC_setLinkCheckMode(0);
            break;
        || case EV_RFU1:
        ||     Serial.println(F("EV_RFU1"));
        ||     break;
        case EV_JOIN_FAILED:
            Serial.println(F("EV_JOIN_FAILED"));  //The node could not join the network
            break;
        case EV_REJOIN_FAILED:
            Serial.println(F("EV_REJOIN_FAILED")); //The node did not join a new network but is still connected to the old network
            break;
    case EV_TXCOMPLETE:          //The dara prepared via LMIC-setTxData() has been sent, and the receive window for downstream data ist complete.
        Serial.println(F("sent"));
        Serial.print(F("Received "));
        Serial.println(LMIC.dataLen);
      break;
        case EV_LOST_TSYNC: //Beacon was missed repeatedly and time synchronization has been lost. Tracking or pinging needs to be restarted
            break;
        case EV_RESET: // Session reset due to rollover of sequence counters. Network will be rejoined automatically to acquiere new session
            break;
        case EV_RXCOMPLETE:
            // data received in ping slot
            break;
        case EV_LINK_DEAD:  // NO confirmation has been received from the network server fpr an extended period of time. Transmissions are still possible but their
                           //reception is uncertain
            break;
        case EV_LINK_ALIVE:
            Serial.println(F("EV_LINK_ALIVE"));  //Link was dead, but now is alive
            break;
        || case EV_SCAN_FOUND:
        ||    Serial.println(F("EV_SCAN_FOUND"));
        ||    break;
        case EV_TXSTART: //This event is reported just before telling the radio driver to start transmission.
            break;
        default:
            break;
void do_send(osjob_t* j) {
 byte ON=1;
static uint8_t mydata[1];
      mydata[0]= ON;
    } else {
        LMIC_setTxData2(1, mydata, sizeof(mydata), 0);
void setup() {
enableInterrupt(uint8_t A5, void (*LowPower.powerDown)(void), uint8_t RISING);
  pinMode(ledPin, OUTPUT); //LED
   digitalWrite(ledPin, HIGH); //LED
  Serial.begin(9600);
  // LMIC init
  os_init();
  LMIC_reset();
  LMIC_setClockError(MAX_CLOCK_ERROR * 1 / 100);  //Relax RX timing window
  os_setTimedCallback(&sendjob, os_getTime() + ms2osticks(10), do_send);
void loop() {
  extern volatile unsigned long timer0_overflow_count;
  os_runloop_once();  //check send status
  if (digitalRead(A5)==LOW) { //if the button is low, then enter sleepmode
    delay(1000);
    Serial.println(F("go to sleep ... "));
    Serial.flush();
    LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);  //Sleepmode
    Serial.begin(9600);
    Serial.println(F("... done sleeping"));
    delay(1000);
    os_setTimedCallback(&sendjob, os_getTime() + ms2osticks(10), do_send);  //do a send
} //loop
i managed to sent arduino to sleep if i press the button. If i let the button go, the arduino is awake. Now i have to solve the problem why i cant send data anymore:sweat_smile:
#include <lmic.h>
#include <SPI.h>
// EnableInterrupt Simple example sketch. Demonstrates operation on a single pin of your choice.
// See https://github.com/GreyGnome/EnableInterrupt and the README.md for more information.
// Modify this at your leisure. Refer to https://github.com/GreyGnome/EnableInterrupt/wiki/Usage#Summary
#if defined __AVR_ATmega640__ || defined __AVR_ATmega2560__ || defined __AVR_ATmega1280__ || \
        defined __AVR_ATmega1281__ || defined __AVR_ATmega2561__
#define ARDUINOPIN A5
#else
// Pin 7 is useful on Arduino Uno, Leonardo, Mighty1284, ATtiny84...
#endif
// 0x70.
static const u1_t PROGMEM DEVEUI[8] = {  0};
volatile uint16_t interruptCount=0; // The count will go back to 0 after hitting 65535.
  .nss = 10,                     //Slave/Master
  .rxtx = LMIC_UNUSED_PIN,       //Antena
  .rst = LMIC_UNUSED_PIN,        //Reset
  Serial.println("TX_Intervall :");
    Serial.print(": ");
    switch(ev) {
            break;
            break;
            break;
            break;
        case EV_JOINING:
            break;
              u4_t netid = 0;
              u1_t nwkKey[16];
              u1_t artKey[16];
              Serial.println("");
              Serial.println("");
            break;
        || case EV_RFU1:
        ||     break;
            break;
            break;
      break;
            break;
            break;
        case EV_RXCOMPLETE:
            break;
            break;
        case EV_LINK_ALIVE:
            break;
        || case EV_SCAN_FOUND:
        ||    break;
            break;
        default:
            break;
 byte ON=1;
      mydata[0]= ON;
    } else {
void setup() {
Serial.begin(9600);
#ifdef MIGHTY1284
  DDRA=0x0;    DDRB=0x0;   DDRC=0x0;   DDRD=0x0; // set all pins as inputs
  PORTA=0xFF; PORTB=0xFF; PORTC=0xFF; PORTD=0xFF; // turn on all pullup resistors.
#else
  pinMode(ARDUINOPIN, INPUT_PULLUP);  // See http://arduino.cc/en/Tutorial/DigitalPins
#endif
  enableInterrupt(ARDUINOPIN, interruptFunction, CHANGE);
  Serial.begin(9600);
  // LMIC init
  os_init();
  LMIC_reset();
void loop() {
 Serial.println("---------------------------------------");
  delay(1000);
  Serial.print("Pin was interrupted: ");
  Serial.print(interruptCount, DEC);
  Serial.println(" times so far.");
    delay(1000);
    Serial.flush();
    Serial.begin(9600);
    delay(1000);
    os_setTimedCallback(&sendjob, os_getTime() + ms2osticks(10), do_send);  //do a send // os_getTime() ist die Systemzeit in ticks
} //loop
void interruptFunction() {
  interruptCount++;
Ok now i can send data and if i press button then my arduino goes to sleep. If i let the button go then he wakes up. The last piece that now is missing is that i want to send data before he goes to sleep. It seems like the entire sending part is connected together. Is there a simple line that i can put there, so i can send data immediately before it goes to sleep?
//here i want send a data, for example ON=2 that the button was triggered.
    Serial.flush();
    Serial.begin(9600);
    delay(1000);
   //Sleepmode end
#include <lmic.h>
#include <SPI.h>
// PINchangeinterrupt von hier
#else
#endif
// For normal use, we require that you edit the sketch to replace FILLMEIN
// with values assigned by the TTN console. However, for regression tests,
// we want to be able to compile these scripts. The regression tests define
// COMPILE_REGRESSION_TEST, and in that case we define FILLMEIN to a non-
// working but innocuous value.
//bis hier
// 0x70.
static const u1_t PROGMEM APPEUI[8]={  };
static const u1_t PROGMEM DEVEUI[8]={  };
static const u1_t PROGMEM APPKEY[16] = {  };
void os_getDevKey (u1_t* buf) {  memcpy_P(buf, APPKEY, 16);}
// cycle limitations).
const unsigned TX_INTERVAL = 5;
// Pin mapping
    .nss = 10,
    .dio = {2, 7, 8},
    Serial.print(os_getTime());
    Serial.print(": ");
    switch(ev) {
            break;
            break;
            break;
            break;
        case EV_JOINING:
            break;
        case EV_JOINED:
              u4_t netid = 0;
              u1_t nwkKey[16];
              u1_t artKey[16];
              Serial.println("");
              Serial.println("");
            break;
        || case EV_RFU1:
        ||     break;
            break;
            break;
        case EV_TXCOMPLETE:
            if (LMIC.dataLen) {
              Serial.print(LMIC.dataLen);
            // Schedule next transmission
            break;
        case EV_LOST_TSYNC:
            break;
        case EV_RESET:
            break;
        case EV_RXCOMPLETE:
            break;
        case EV_LINK_DEAD:
            break;
        case EV_LINK_ALIVE:
            break;
        || case EV_SCAN_FOUND:
        ||    break;
        case EV_TXSTART:
            break;
        default:
            break;
 byte ON=1;
//Payload part
      mydata[0]= ON;
    } else {
void setup() {
//Pinchange interrupt von hier
Serial.begin(9600);
#ifdef MIGHTY1284
#else
#endif
//bis hier
    Serial.begin(9600);
    // LMIC init
    os_init();
    LMIC_reset();
    do_send(&sendjob);
void loop() {
    os_runloop_once();
  /*  Serial.println("---------------------------------------");
  delay(1000);
    Serial.flush();
    Serial.begin(9600);
    delay(1000);
   //Sleepmode end
void interruptFunction() { //  Pinchangeinteruput part
  interruptCount++;
does somebody know how i can send data immediately when the button is pressed?
I tried it that way, but i just receive on serial monitor “Packed queued” but no data in the TNN console.
    os_init();
    LMIC_reset();
    do_send(&sendjob);
    Serial.flush();
    Serial.begin(9600);
    delay(1000);
