Simple Azure IoT Hub client for Multitech Conduit
Hi everyone,
I thought I’d share with you a little application I made for the Multitech MultiConnect Conduit. It is completely open source, written in pure C, based on some examples from Microsoft’s Azure IoT Hub C SDK and designed to be a minimal example of how you might use a Conduit to forward LoRaWAN packets to an Azure IoT Hub instance. You can find the source code along with simple instructions here:
https://github.com/ljmarks/multitech-conduit-lora-iot
Apologies if this is an inappropriate post – I’d be happy to move it to a different category or otherwise remove it altogether.
